Post by Dixie Dean on Sept 21, 2019 8:51:00 GMT 1
Hi everyone should ypvs oil pump still have oil going to carbs when engine not running?
Post by andy748 on Sept 21, 2019 8:57:01 GMT 1
Hello mate, if you mean are the pipes primed with oil, then yes, are you running clear lines? Andy.
Post by Dixie Dean on Sept 21, 2019 9:00:55 GMT 1
Hi black lines oil still seaps from lines pump primed
Post by rigga on Sept 21, 2019 9:03:05 GMT 1
Proper clips fitted to the pipes?
Post by andy748 on Sept 21, 2019 9:08:34 GMT 1
If they seep, then replace, if oil gets out then they are probably a sloppy fit and when under pressure may pop off when you're out on it especially when they warm up and soften. As Rigga states, make sure the Yamaha clips are fitted at both ends? Andy.
Post by andy748 on Sept 21, 2019 9:12:29 GMT 1
Oh, and your check valves may be knackered in your pump, send it to Arrow for a re-furb. Andy.
Post by Dixie Dean on Sept 21, 2019 9:36:29 GMT 1
Have you got arrows details.
Post by andy748 on Sept 21, 2019 9:52:02 GMT 1
Search for him on the members section of this forum and drop him a p.m. he'll make it as new. Andy.
Post by andy748 on Sept 21, 2019 9:54:15 GMT 1
He's on page 10 of the members page Dixie. Andy.
Post by midlifecrisisrd on Sept 21, 2019 10:35:47 GMT 1
Biggest issue is non return valves in pump not sealing
Oil syphons from the tank as it is higher
