Post by headcoats on Aug 17, 2019 22:15:44 GMT 1
After coming to the conclusion the TSX Hi Lex cables are utter shite "> "> I need a decent make clutch cable for the Hybrid It needs to have the bend in it by the handle bars So what's out there or bite the bullet and get a Yamaha jobby !
Post by dave1963 on Aug 17, 2019 22:34:32 GMT 1
Got a genuine yam 2006 ybr125 on mine part no 3d9f63351100 about £13 and has an adjuster in the middle as well
Post by headcoats on Aug 17, 2019 22:56:48 GMT 1
Has it got the magic bend in it :-)
Post by dave1963 on Aug 17, 2019 23:42:42 GMT 1
Yes mate it has but its not dark metal more like chrome you have to open up the slot in the top case about 1mm for it to fit
Post by bare on Aug 18, 2019 2:47:12 GMT 1
Fitted what I believe was a Yama R6 one to my LC mitt Valvie engine. Bit of a rascal to sort out a decent routing to fit it's Longer length. Works well tho .. No metal bend bits,, slippery as a greased pig (hard to keep the thing in it's sleeve during instal). Plus it has a threaded Engine end. Meaning the Crap Valvie OEM yama spring clamp contraption deservedly went into the trash bin. As the threaded end could be solidly bolted onto the case bosses, which provides a Second adjustment point.. should one need it
Post by headcoats on Aug 18, 2019 8:32:35 GMT 1
Was looking at an R6 one but routing a "straight" cable looks a pig to do
Does anyone have the part number for the genuine ypvs one with the fabled bend :-)
Post by dusty350 on Aug 18, 2019 8:43:44 GMT 1
If it's the F2 cable, it's 1ua 26335 01. Fowlers have them in stock at £32.52. Dusty
Post by jon on Aug 18, 2019 8:47:26 GMT 1
1UA2633501
£32.52
Not really that expensive to justify not fitting one IMO.
Post by jon on Aug 18, 2019 8:47:48 GMT 1
Snap
Post by headcoats on Aug 18, 2019 9:52:51 GMT 1
nearly £40 with post !
Got a Slinky one on the Triumph and good quality but the one advertised doesn't have the bend Wemoto are the importer
Post by midlifecrisisrd on Aug 18, 2019 10:53:44 GMT 1
nearly £40 with post ! Got a Slinky one on the Triumph and good quality but the one advertised doesn't have the bend Wemoto are the importer Only £3 post from Fowlers. Spend another £18 and over £50 is free post As said ybr125 or a 1ua cable I can check if I have a good used one Steve
