Post by headcoats on Aug 17, 2019 11:16:21 GMT 1
I have used Ramair in the past but not that impressed with them , so what do other folks use ?
It's in an LC so not that much room is there but would like maximum sized filters
Post by stusco on Aug 17, 2019 11:35:09 GMT 1
I’ve had Norbo’s and ramair they all fall apart eventually ,I think ramair look better but that’s just my opinion
Post by rigga on Aug 17, 2019 12:00:06 GMT 1
Can't use a airbox? Just don't use closed end filters, all foam ones are best.
Post by Tobyjugs on Aug 17, 2019 12:49:45 GMT 1
One fell apart on me as well, i got a pair made up to my spec in a motocross shop. I also had a choice of colours for the foam. They are as tough as old boots compared to the Ram air filters
Post by tacky1 on Aug 17, 2019 15:15:06 GMT 1
I run the Uni Filter NU-4060ST filters on my bikes, I also fit a K&N outerware, keeps them clean..
Post by headcoats on Aug 17, 2019 15:46:41 GMT 1
Is there a UK stockist for the uni filter
Post by bare on Aug 18, 2019 2:52:17 GMT 1
Years ago Proven that the oem Airbox produces Mo' power than add on filters.. certainly so on other than Dedicated Race only engine setups. Carb/intake Access to a Still Air plenum is the underlying reason allegedly
Post by steeley on Aug 21, 2019 8:47:37 GMT 1
I fitted this set up on the yamagamma ,to a pair of 30mm oko carbs . yes stop laughing at the back I know the welding is crap
Post by dusty350 on Aug 21, 2019 9:09:13 GMT 1
Some of the Uni filters come with an angled mounting rubber, so you can tip the filter 15 degrees away from a frame tube or other obstruction. That would be good for my Café racer build as normal foam filters would get a bit squashed against said tubes. Haven't found a Uk stockist yet - surely someone must do them over here ? Dusty
