Deano
Boxhill
Aug 15, 2019 17:57:35 GMT 1
Post by Deano on Aug 15, 2019 17:57:35 GMT 1
off up to boxhill tonight if anyone wants to meet up 👍🏻 Weather looks ok
Deano
Post by Deano on Aug 16, 2019 9:54:14 GMT 1
Didn’t go to plan last night....I filled it up with diesel 😱....realised when I put nozzle back on pump...didn’t start it I had to drain off in Gerry cans...filled back up with petrol smoking more than normal....will there be any issues with my complete f@#k up 😳
Boxhill
Aug 16, 2019 10:14:20 GMT 1
Post by earthman on Aug 16, 2019 10:14:20 GMT 1
Do you think that you drained 99% of it out? Without say removing the tank from the bike and swaying it about etc, there's bound to be a small amount/residue still present. I can imagine that you would see a bit more smoke, hopefully it clears soon and you have got away with it.
Deano
Boxhill
Aug 16, 2019 10:45:43 GMT 1
Post by Deano on Aug 16, 2019 10:45:43 GMT 1
Yes did exactly what you said above....just taken it out again to use more fuel up....topped up another £6 quid to dilute more
Boxhill
Aug 16, 2019 17:11:17 GMT 1
via mobile
Post by midlifecrisisrd on Aug 16, 2019 17:11:17 GMT 1
You will be fine
Boxhill
Aug 16, 2019 17:28:22 GMT 1
Post by jon on Aug 16, 2019 17:28:22 GMT 1
Is it not the other way round it causes more damage?
neil
my 125
Boxhill
Aug 16, 2019 17:41:42 GMT 1
via mobile
Post by neil on Aug 16, 2019 17:41:42 GMT 1
Yes petrol in diesels can be worse! I recon it will be fine just take it easy for a tank of fuel.
Boxhill
Aug 16, 2019 18:05:53 GMT 1
via mobile
Post by midlifecrisisrd on Aug 16, 2019 18:05:53 GMT 1
Is it not the other way round it causes more damage? Jon Even more so on the old mechanical injection engines The diesel lubricated the pump so used to eat themselves with neat petrol Steve
Deano
Boxhill
Aug 16, 2019 20:25:04 GMT 1
Post by Deano on Aug 16, 2019 20:25:04 GMT 1
Thanks lads 👍🏻
Post by earthman on Aug 17, 2019 7:52:17 GMT 1
Is it not the other way round it causes more damage? Jon Even more so on the old mechanical injection engines The diesel lubricated the pump so used to eat themselves with neat petrol Steve Some years ago now one of the TV car shows experimented with the wrong fuel in two cars, they both still fired up/ran but the diesel came out worse and like you say, would have totally destroyed some components fairly quickly. Petrol is a pretty good cleaner at the end of the day.
mervin
Boxhill
Aug 17, 2019 15:43:23 GMT 1
Post by mervin on Aug 17, 2019 15:43:23 GMT 1
I filled a honda dominator half full with diesel once , it ran the 15 miles home ok while hot , but it was hard to start the next day , rode it a mile up the road it seemed a bit flat , got off walked behind and smelt diesel , went home drained the tank , put a gallon of petrol in started it up rode to garage filled it up . no problems to this day , 10 years ago my mate put petrol in his diesel landy , he got home before realising it , but landy was sounding a bit sick , drained it off, put fresh diesel in started up and is still running to this day , gave diesel/petrol mix to a farmer he used it up in his old tractor gradually
Boxhill
Aug 18, 2019 11:41:44 GMT 1
via mobile
Post by Deleted on Aug 18, 2019 11:41:44 GMT 1
Many years ago I filled a petrol generator with diesel...it ran like shit, but ran anyway. After changing the fuel it was good as gold. Earlier this year I filled my Nissan Navara diesel with petrol, and it stopped within minutes. I drained and purged it, but it was never quite right again. Had to trade the b*****d in!
Boxhill
Aug 18, 2019 12:04:11 GMT 1
via mobile
Post by midlifecrisisrd on Aug 18, 2019 12:04:11 GMT 1
Talking of running stuff on wrong fuel
Years ago (still at school) a mate had an mt5. Absolutely no fuel in it and bored we took a camping gas cylinder and connected the hose to the vent spigot on the fuel cap.
Turned on the gas, pulled out the choke and kickstarted it
It only went and fired up to our amazement
Pity it would only idle, any throttle and it died on its 4rse
Boxhill
Aug 18, 2019 12:31:06 GMT 1
Post by rich on Aug 18, 2019 12:31:06 GMT 1
We had an '08 plate Vito recovered in last week, bloke had put 5 litres of Adblue in the diesel tank and ran it till it cut out. All we could do was drain the tank (we have the proper kit), replace the fuel filter, put in £20 of fresh diesel and hope for the best. Not a chance in hell. Gave it a couple of tries but then gave up completely. One of our guys cracked off an injector pipe and it was like milk coming out. Apparently this stuff crystallises and coats everything inside the fuel system. Only fix is to replace the entire system - tank, lines, pump and injectors which on an '08 Vito with 160k on the clock was way more than it was worth.
I did explain this to the guy but I'm sure he thought we were trying it on as he had it further recovered to another garage!
