Post by lesrd80lc on Aug 14, 2019 19:15:13 GMT 1
Hi does anybody know what the torque settings are for the head bolts on the RD80lc 2 30w German import ive had 2 head gaskets on had the head skimmed and checked for cracks but it is still weeping water; I’m just may be thinking I’m tightening it to much : any ideas
Post by marsbar350 on Aug 14, 2019 19:25:20 GMT 1
hi les lose the water first off a bit of sealant on the gaskets then run up till you cant hold your hand on the barrels let it cool down.retorque head 20ft/lbs refill with coolant should be good to go
Post by lesrd80lc on Aug 14, 2019 20:22:13 GMT 1
Cheers I’ll give that a go
Post by lesrd80lc on Aug 15, 2019 20:18:58 GMT 1
Cheers for that I’ve fitted as you have said and I have no leaks top tip mate thank you
