Post by botty on Aug 14, 2019 16:09:38 GMT 1
I was ill advised and used fully synthetic gear oil.
The clutch now slips.
So want to convert back to mineral.
Is it a simple drain and replace. Or more to it??
Strip clutch and clean off oil etc
Post by cb250g5 on Aug 14, 2019 18:10:07 GMT 1
There's nowt wrong with fully synth oil. You just need to avoid car oils, as they have friction modifiers that will make your clutch slip.
I'd strip the clutch pack, wash the plates in a solvent (petrol) and rebuild after soaking in your chosen oil overnight.
Post by midlifecrisisrd on Aug 14, 2019 18:19:54 GMT 1
What did you put in it?
Fully synthetic bike oil should be fine
Years ago when I was skint I had a kwak 750 turbo that I used to stick any car oil in as I could sneak it on my company car fuel card 😆
Never had a problem but probably lucky
Post by botty on Aug 14, 2019 18:37:59 GMT 1
It was Motul synthetic trans oil.
Post by stusco on Aug 14, 2019 18:51:03 GMT 1
I had a look it doesn’t say suitable for wet clutches
Post by botty on Aug 14, 2019 19:12:02 GMT 1
I had a look it doesn’t say suitable for wet clutches I was recommended it by a bike shop 😤
Post by botty on Aug 14, 2019 19:13:01 GMT 1
I had a look it doesn’t say suitable for wet clutches I was recommended it by a bike shop 😤 Possibly because they didn’t have 2 mineral
Post by marsbar350 on Aug 14, 2019 19:14:38 GMT 1
why do you always have to do things twice antoine
Post by botty on Aug 14, 2019 20:39:46 GMT 1
why do you always have to do things twice antoine 😂😂I was advised wrong 😟😟
