Post by dalmahoy on Aug 14, 2019 10:53:01 GMT 1
Out on the 4L0 last night and I noticed a little wear between the gear shifter and engine casing. The seal in the crankcase is fine - with any wear appearing limited to the outer casing. Before I strip the thing - is the bush or bearing in the outer casing available? Looked on a couple of sites and I couldn't see it listed. Cheers
Post by midlifecrisisrd on Aug 14, 2019 11:13:32 GMT 1
Don't think there is a part as such but on my last build I replaced it
The ypvs had a bush in the crankcase which is only a few quid so I bought one, drilled out the side case with a pillar drill then pushed in the ypvs bush with a bit of epoxy on it to help bond it in
Post by oldbritguy on Aug 14, 2019 11:18:41 GMT 1
Don't think there is a part as such but on my last build I replaced it The ypvs had a bush in the crankcase which is only a few quid so I bought one, drilled out the side case with a pillar drill then pished on the ypvs bush with a bit of epoxy on it to help bond it in Steve Pished on it Steve? That is a bit uncouth for a man of your standing on this fine forum
Post by midlifecrisisrd on Aug 14, 2019 11:24:05 GMT 1
Don't think there is a part as such but on my last build I replaced it The ypvs had a bush in the crankcase which is only a few quid so I bought one, drilled out the side case with a pillar drill then pished on the ypvs bush with a bit of epoxy on it to help bond it in Steve Pished on it Steve? That is a bit uncouth for a man of your standing on this fine forum Oh dear 😳, auto correct at its best lol I am suitably chastised and have corrected the offending article 😂 Steve
Post by lolly on Aug 14, 2019 13:43:29 GMT 1
Out on the 4L0 last night and I noticed a little wear between the gear shifter and engine casing. The seal in the crankcase is fine - with any wear appearing limited to the outer casing. Before I strip the thing - is the bush or bearing in the outer casing available? Looked on a couple of sites and I couldn't see it listed. Cheers www.ebay.co.uk/itm/Yamaha-Rd-250-lc-Gear-shaft-Fix-/273947147686?hash=item3fc885bda6
is this what your after ? if so they works a treat ; did mine about 6 months ago
Post by dusty350 on Aug 14, 2019 14:30:17 GMT 1
I had a case on a previous build that was missing the bush altogether. I found a roller bearing; 38033351721_e5e636d284_b by dusty miller, on Flickr Had to enlarge the hole in the case a bit as the bearing has an 18mm OD, but took just enough out to make it a tight press fit. Should last forever hopefully ! 24192114198_fd30153559_k by dusty miller, on Flickr Dusty
Post by dalmahoy on Aug 14, 2019 21:32:33 GMT 1
Sure thats for the crankcase not the outer casing. I'll keep it save though just in case the crankseal does start to leak.
Post by shaunthe2nd on Aug 14, 2019 21:39:32 GMT 1
Used this fix twice now with good results.
Post by dalmahoy on Aug 15, 2019 7:18:37 GMT 1
Looks a pretty doable repair. Looking at drilling, reaming then fit a phosphor bronze bush. Thanks for all the tips and advice - it's most appreciated.
Post by chrisg on Oct 13, 2019 20:16:05 GMT 1
Looks a pretty doable repair. Looking at drilling, reaming then fit a phosphor bronze bush. Thanks for all the tips and advice - it's most appreciated. There was a company on EB that sold a press in bush in place of the seal and had a seal fitted on the outside to get round the wear. Ive not seen it for a while but keep a look out. picclick.co.uk/Yamaha-Rd-250-lc-Gear-shaft-Fixbushed-273971292970.html
Post by dalmahoy on Oct 14, 2019 11:04:17 GMT 1
Chris - that looks like the crankcase - it's the outer casing I need sleeved.
