tomtom1
Leeds
Post by tomtom1 on Aug 13, 2019 19:11:42 GMT 1
Hi all Just bought a 31k and while I had exhausts off I noticed the power valve joining piece between the two cylinders have the bolts facing down while engine not running, does anyone know if this is right.?
Thanks
Post by Yogi on Aug 13, 2019 19:27:12 GMT 1
You should be able to see the bolt heads from the front If you can’t ,unbolt the pulley on the left barrel,rotate the valves 180% then reconnect
Matt
tomtom1
Leeds
Post by tomtom1 on Aug 13, 2019 19:31:10 GMT 1
Hi Matt
I can see them but should they face down to the ground or up towards the fuel tank? Cheers
Post by Yogi on Aug 13, 2019 19:34:33 GMT 1
Bolt heads should be near the top,I’ll put a pic up now
Post by oldbritguy on Aug 13, 2019 19:35:30 GMT 1
When you say facing down do you mean the screw heads are on the under side? I have just fitted new PVs this afternoon and the screws on the joint piece are at the top. Set the PV pulley to the fully open position lining up the notch and hole using a drill bit at the top. Look inside the exhaust ports and see if your valves are not obstructing the port i.e the port shape should be almost round and you can see the pistons. If the port is obstructed by the power valve i.e you can see the round body of the valve across the port opening then the valves are in upside down. I think you can spin them round 180 while in place and refit the pulley.
Post by oldbritguy on Aug 13, 2019 19:36:45 GMT 1
Yogi beat me to it
Post by Yogi on Aug 13, 2019 19:37:32 GMT 1
Matt
tomtom1
Leeds
Post by tomtom1 on Aug 13, 2019 19:38:00 GMT 1
When you say facing down do you mean the screw heads are on the under side? I have just fitted new PVs this afternoon and the screws on the joint piece are at the top. Set the PV pulley to the fully open position lining up the notch and hole using a drill bit at the top. Look inside the exhaust ports and see if your valves are not obstructing the port i.e the port shape should be almost round and you can see the pistons. If the port is obstructed by the power valve i.e you can see the round body of the valve across the port opening then the valves are in upside down. I think you can spin them round 180 while in place and refit the pulley. Hi yes my bolt heads are facing the ground
Post by Yogi on Aug 13, 2019 19:39:45 GMT 1
Yogi beat me to it Lol,I might have been quicker but you explained it better 🤣😉
tomtom1
Leeds
Post by tomtom1 on Aug 13, 2019 19:57:36 GMT 1
That would explain a lot. I've just removed the pully, spun power valves 180deg, so now with engine off the the PV cutaway is the same as exhaust cutaway so open as much as possible, where before I spun the pv the exhaust port was partly closed off. Does that all sound right guys? Thanks
Post by Yogi on Aug 13, 2019 20:03:05 GMT 1
Spot on Turn the ignition on,let it do it’s clean cycle then adjust the cables so the half moon at the top of the pulley is in line with the hole behind it
Matt
tomtom1
Leeds
Post by tomtom1 on Aug 13, 2019 20:21:18 GMT 1
Thanks guys nice easy fix😁
