Post by wallcraft on Aug 10, 2019 23:53:39 GMT 1
Gents Anyone used or opinions on the quickfoot 70 D-Cat ( Dot Laser) chain alignment tool on their LC sprocket? Thinking about buying one off the Bay. Cheers Mark.
Post by Tobyjugs on Aug 11, 2019 0:13:01 GMT 1
Ive got one and it's a good tool to have. Im not sure which make and model it is but it's German made. I use it at work and for my motorcycle chain alignment.
I have found that its best to check the alignment over 4 equally spaced points of the sprocket as you sometimes have a little lateral play in the rear sprocket assembly.
Post by cbm on Aug 11, 2019 7:33:36 GMT 1
Used one for years, they make the job so easy
Post by midlifecrisisrd on Aug 11, 2019 10:31:20 GMT 1
Post by 4l04ever on Aug 11, 2019 13:59:04 GMT 1
I have a Profi SE-CAT laser, but not working over Coventry anymore. If you fancy a ride over to Dudley, you can check your bike with it.
tlmark
Post by tlmark on Aug 11, 2019 14:07:14 GMT 1
I bought a chain monkey but if you have a chain guard ( most people) It gets in the way And now use a hold on the sprocket type much better and they make a big difference to chain and tyre wear
Post by earthman on Aug 11, 2019 14:13:34 GMT 1
I have a Profi LE-CAT one, there are at least two versions, I went for the solid laser line as opposed to the single dot one, that can still get washed out in the daylight though so you need a garage/shaded area for the best view.
Post by Tobyjugs on Aug 11, 2019 15:13:48 GMT 1
I have a Profi LE-CAT one, there are at least two versions, I went for the solid laser line as opposed to the single dot one, that can still get washed out in the daylight though so you need a garage/shaded area for the best view. The one i use makes a solid line as well. Ive only ever used it in my garage or in an engine so I've never noticed that pitfall.
Post by wallcraft on Aug 11, 2019 22:44:32 GMT 1
Brill, thanks gents, probably get one now. Bit of a luxury now after all these years of trusting arm markings or in some cases lack of arm markings. Things move on I suppose. Cheers Rob I'll have a ride over when spare time allows for a chat and test yours.👍
Mark.
