Post by headcoats on Aug 10, 2019 13:38:47 GMT 1
What is the easiest way to get these pesky tab washers bent over the nuts as it always seems feckin awkward to me
Also removing them, what's the best method ?
Post by midlifecrisisrd on Aug 10, 2019 13:47:46 GMT 1
The new washers have a section slightly bent over so you can get a big driver under the corner and lever it over
Then some gland pliers to fold over before a final tap if needed with a hammer and cold chisel
To get the bolts off I have a driver filed to a knife edge to pry under them.
After that a rattle gun loosens easily or a flattened bit of copper pipe jamming the primary gears then a socket.
Post by headcoats on Aug 10, 2019 14:38:09 GMT 1
Silly question but what are gland pliers ?
When I did the 2002 Bonneville's clutch basket, it had a bevel washer like the one that goes on the LC's primary drive , so is a tab washer on the clutch basket old hat now ?
Post by midlifecrisisrd on Aug 10, 2019 15:22:34 GMT 1
Glad.d pliers/water pump pliers π I'll get a pic lol
The old aircooled were levelled, they moved onto the tab.
Talking of tabs I had to buy 3 tabs and 6 nuts for a 1kt sprocket carrier yesterday
Fecking Β£30 π€¬
Post by midlifecrisisrd on Aug 10, 2019 15:23:49 GMT 1
These Steve
Post by Yogi on Aug 10, 2019 15:56:04 GMT 1
These Steve We call them 5 holes on my planet πππ
Post by headcoats on Aug 10, 2019 16:06:12 GMT 1
AHA LOL now I know :-)
Clutch centre nut on YPVS says 65ft pounds while the LC manual says 54 ft pounds
So is the higher one for the YPVS correct or a typo !
Post by midlifecrisisrd on Aug 10, 2019 16:28:35 GMT 1
Not near a manual so can't check
Its somewhere around 60
Post by Tobyjugs on Aug 10, 2019 16:37:58 GMT 1
AHA LOL now I know :-) Clutch centre nut on YPVS says 65ft pounds while the LC manual says 54 ft pounds So is the higher one for the YPVS correct or a typo ! The threads are different on the input shafts. 4LO is M18 YPVS is M20
Post by headcoats on Aug 10, 2019 16:46:27 GMT 1
So correct then ?
Post by Tobyjugs on Aug 10, 2019 18:09:58 GMT 1
Yes the figures you quoted are good.
Post by stusco on Aug 10, 2019 20:35:11 GMT 1
Pump pliers or Gordonβs
Post by pdxjim on Aug 11, 2019 7:50:28 GMT 1
LOL, not those damn Channel Locks again ...
... anyway, just a note that the tab washers from Shambits are twice the thickness of the gen Yam ones and are a right b@stard to get folded over.
That is all.
Post by dusty350 on Aug 11, 2019 8:06:07 GMT 1
Shambits strike again !! I use pump pliers too, but it's still an awkward job ! Dusty
Post by Tobyjugs on Aug 11, 2019 9:09:58 GMT 1
The trick is to bend the locking tab slightly up before you fit it.
