Post by hjw on Aug 7, 2019 20:15:20 GMT 1
hi there, looking at upgrading the front brake. The blue spot r6 calliper fits, this needs a adapter does it also require the r6 disc?
cheers hjw
Post by midlifecrisisrd on Aug 7, 2019 20:24:28 GMT 1
Blue spot fits with an adaptor bracket
It uses the standard rd disc
Post by hjw on Aug 7, 2019 20:39:17 GMT 1
Thanks that helps a lot
Hjw
Post by 4l04ever on Aug 9, 2019 18:12:03 GMT 1
Adapter bracket can be purchased from NK Racing or other sources.
Post by hjw on Aug 9, 2019 20:56:15 GMT 1
Great I have a pair on order. Got a pair of blue spot callipers on the bay. Just going to use one at present but have the option now to upgrade to twin up front in the future
Thanks for your advice
Hjw
Post by hjw on Aug 10, 2019 13:51:02 GMT 1
Blue spot callipers arrived and seam to be in very good shape, so a quick strip and clean will do
Hjw
Post by 4l04ever on Aug 10, 2019 13:59:31 GMT 1
If you are only running one caliper, I would suggest using a YBR125 front master cylinder which is 11mm bore.
Post by hjw on Aug 11, 2019 17:14:31 GMT 1
Do you have a suggestion for running twin discs.?
Post by 4l04ever on Aug 11, 2019 17:29:37 GMT 1
Let me do the math(s).
5.5 x 5.5 X 3.14159265359 = 95mm2 for one 11mm master cylinder
So would need roughly 190mm2 for twin discs
sqr(190/pi) = 7.7mm radius, which equals 15.4mm diameter. 5/8" = 15.875mm so that would be nearest, so a standard 4L0 master cylinder it is! :-)
Post by Tobyjugs on Aug 11, 2019 18:29:31 GMT 1
Let me do the math(s). 5.5 x 5.5 X 3.14159265359 = 95mm2 for one 11mm master cylinder So would need roughly 190mm2 for twin discs sqr(190/pi) = 7.7mm radius, which equals 15.4mm diameter. 5/8" = 15.875mm so that would be nearest, so a standard 4L0 master cylinder it is! :-) Great to see things explained properly.
