Post by headcoats on Aug 4, 2019 13:17:16 GMT 1
What can I use for attaching the stator to the cases ? Could I use Allen bolts or maybe low profile ones or does anyone have the part number for genuine ?
Post by Deleted on Aug 4, 2019 13:33:50 GMT 1
I thought nk they are just an M6 hex hd bolt, not sure what length though
Post by headcoats on Aug 4, 2019 14:12:03 GMT 1
Just not sure how much gap there is when you fit flywheel The plate isn't adjustable like LCS so once on it doesn't need adjusting for the timing
Post by dusty350 on Aug 4, 2019 18:50:38 GMT 1
If you want genuine Yam, the bolt is 97024 06020. Fowlers have them at 91p each. Washers are 90201 06042. £1.61 each, in stock too. Dusty
Post by headcoats on Aug 5, 2019 10:48:57 GMT 1
Cheers dusty
So the code is saying they are M6 x 20mm long
Post by oldbritguy on Aug 6, 2019 13:49:52 GMT 1
I have just fitted new ones on my rebuild Pic of one of the old ones and plate washer for ref
Post by headcoats on Aug 6, 2019 14:32:12 GMT 1
Cheers Got a bag of clutch springs with about 3 different types in next ! I want to fit 3 standard and 3 heavy duty ones
Post by midlifecrisisrd on Aug 6, 2019 14:40:23 GMT 1
Cheers Got a bag of clutch springs with about 3 different types in next ! I want to fit 3 standard and 3 heavy duty ones Standard usually have some yellow paint on them Steve
Post by headcoats on Aug 6, 2019 15:00:42 GMT 1
Might have to buy 3 standard springs then !
LC manual says 34.9mm free length but YPVS book says 36.4mm ! Thought they were the same
So any aftermarket ones (heavy Duty types) would need to be LC or YPVS specific but not both ?
Just to be square I have
34.50 32.81 35.38 34.28 42.38 42.26 41.78 42.44 35.22 35.55 34.74 35.41
So according to that , they are good for the bin !
Post by wallcraft on Aug 6, 2019 23:37:05 GMT 1
Your gonna need 3 TZ springs at least if your running the Athena top end.
Post by dusty350 on Aug 7, 2019 7:20:25 GMT 1
Just cross referenced an Lc and Pv F2 parts fiche. Different part numbers for the clutch springs between bikes, so they are different. Dusty
Post by headcoats on Aug 7, 2019 7:34:24 GMT 1
Do you have the part number for the ypvs ones Dusty
Post by dusty350 on Aug 7, 2019 7:45:31 GMT 1
Yep, F2 Pv - 90501 23138. Dusty
Post by headcoats on Aug 7, 2019 8:26:05 GMT 1
Cheers ! Anyone know the TZ springs part number ? I guess there are different models over the years ?
Post by cb250g5 on Aug 7, 2019 8:30:02 GMT 1
If you want to check spring rates, put 2, end-end, in a vice and slowly squeeze, the lighter one will close up 1st.
Post by headcoats on Aug 7, 2019 8:46:37 GMT 1
Post by headcoats on Aug 7, 2019 18:34:46 GMT 1
Just ordered some EBC heavy duty springs and the bloke said they measured 36mm even though they are advertised for LCS YPVS and RD 400 !
So just need 3 standard ones now
Post by Tobyjugs on Aug 8, 2019 9:13:08 GMT 1
If you want to check spring rates, put 2, end-end, in a vice and slowly squeeze, the lighter one will close up 1st. That's a great tip. The last time I spent ages staffing around with a weight and measuring the compression.
Post by cb250g5 on Aug 8, 2019 10:20:00 GMT 1
If you want to check spring rates, put 2, end-end, in a vice and slowly squeeze, the lighter one will close up 1st. That's a great tip. The last time I spent ages staffing around with a weight and measuring the compression. Should have said, stick a 2p or washer or something between them as well, rather than trying to get the coils lined up exactly. I had a bag full, some were supposed to be HD ones, but all mixed up, so I just graded them from light to heavy & chose the ones I wanted. In the end I think I settled on lightest springs, but the meatier plates, from the big diesels, and all is well. Don't want a heavy pull, the T140 used to kill my hand in traffic.
Post by headcoats on Aug 8, 2019 11:09:02 GMT 1
Bloke used to come to the local meets on a hybrid and had 6 heavy duty springs on a stubby clutch lever and you could hardly pull it in 😱
