Post by jon on Jun 26, 2019 19:01:19 GMT 1
Hi all,
Does anyone have a wiring diagram for the 350R model? I think it’s the same as an F2 which I have, but you never know?
I’m a bit stumped on the last bit connecting the front indicators.
I can get them to come on and stay on front and back either side, but they don’t flash. It’s a 2 wire flasher unit with a brown and brown and white wire going into it.
Is one of the terminals on a 3 wire version an earth? If so can they be adapted?
Faulty flasher relay or wiring not connected properly?
There are only 3 wires for the indicators to fit to. A double green, a black and a brown. From what I can make out the black is the earth, green the right and brown the left.
Post by midlifecrisisrd on Jun 26, 2019 19:08:59 GMT 1
I never managed to find a diagram for the r
Manual says it's the same as f2 but it isn't.
Basics are the same but no side stand control unit, no self cancel Indies and of course the headlights.
I'd suspect the relay as long as you have the front Indies connected properly
One side is dark green, other is dark brown
If the green is on a double wired bullet I'd expect the dark brown to be on a double wire
Make sure builds are both 21w and you haven't mixed the wiring up with the front brake switch
Post by jon on Jun 26, 2019 19:44:45 GMT 1
I have two R looms, and I think both have the sidestand switch connector.
The R has a engine kill unless in neutral too.
Front brake switch works fine.
I think I suspect the flasher unit?
Post by midlifecrisisrd on Jun 26, 2019 21:05:19 GMT 1
Most likely that. Think on the 3 pin relay the 3rd wire was the self cancel trigger
Yes the r does have a side stand switch like the f2 but the way it works is different
On the r the extra wire on the cdi connects into the neutral light circuit.
If it's in neutral or the stand is up it's connected to 0v so allows the bike to run
On the f2 there is a side stand control module that the switch connects to and operates the kill circuit
Post by jon on Jun 27, 2019 17:47:45 GMT 1
I’ve ordered a new flasher relay. Have to see if that’s it.
Post by fecklessijit on Jan 8, 2020 9:39:30 GMT 1
Jon did you find your problem??? I have an issue with indicators right now but I’m chasing the issue . Any news on a wiring diagram ?
Post by jon on Jan 8, 2020 9:58:52 GMT 1
The problem was the flasher unit as I suspected. I bought a new one and it was fine.
As said before, I’ve never found a wiring diagram. However they are so similar to an F2 for instance that it’s not a problem.
