Post by alistair64 on Jun 16, 2019 18:32:17 GMT 1
Hi Was wondering what you'd use to seal the joint between the end can and expansion chamber flange. I have Lomas pipes with Gibson cans and they've sprayed oil from the joint for a while now (not badly). Took off the cans today and was surprised to see no gasket or sealant of any kind, even though they were assembled by a pipe manufacturer and not myself. Was thinking Threebond on the mating surface and on the 2 retaining studs, but the 1184 which I have will withstand up to 150 degrees C. Is that enough, or am I better off using a car exhaust assembly paste? Or maybe cut out a thick paper gasket for a neater job?
Thanks.
Post by LC_BOTT on Jun 16, 2019 19:29:00 GMT 1
I've used threebond, and hasn't leaked so far, put it on all surfaces before fitting, never thought about the temp range. Bathroom sealant worked on my car exhaust just fine too
Post by dave1963 on Jun 16, 2019 19:41:12 GMT 1
I make my own gasket out of 2mm gasket paper works great
Post by marsbar350 on Jun 16, 2019 19:52:01 GMT 1
Post by midlifecrisisrd on Jun 16, 2019 20:05:26 GMT 1
I'm sure member 4l04ever did me gaskets for the end can flanges
Post by dusty350 on Jun 16, 2019 20:08:57 GMT 1
I use 3 bond too Dusty
Post by alistair64 on Jun 16, 2019 21:30:03 GMT 1
Cheers guys. Looks like Threebond, paper gaskets or that Envirograf stuff will do the job just fine.
