Post by kitch on Jun 9, 2019 12:45:26 GMT 1
Hi,wondered if anyone can help, everything on my 83 ypvs works except front and rear lights. Brake light is fine just no lights when switch is operated. Cheers
Post by stusco on Jun 9, 2019 13:55:00 GMT 1
I’d guess the switch gear or the fuse ,my lc fuse box is crap and the fuse comes loose everything else works except the lights so it’s now jammed in and held closed with a tie wrap
Post by wangwang on Jun 9, 2019 15:06:48 GMT 1
I'd check the switch or connector block.
Post by doohanno1 on Jun 10, 2019 20:01:09 GMT 1
Well kitch you put the mockers on it.. Went to go for a spin on the pv this evening when i noticed i had no lights.. Had a look at the switch and all looked good..Looked at the fuses, aha headlight one blown..even i can fix that.... Put a new one in ,bang.... Have a bloody short somewhere.. How hard can electrics be,red to red , black to black and so on...🙄
