Post by Dixie Dean on Jun 2, 2019 11:38:53 GMT 1
Hi anybody no if mutts nutts is open on a Sunday?
Post by muttsnuts on Jun 2, 2019 12:38:22 GMT 1
no I am not, family day Sunday
Post by Dixie Dean on Jun 2, 2019 12:53:30 GMT 1
Good call speak with you tomorrow
Post by veg on Jun 2, 2019 15:51:03 GMT 1
What youβre self employed man you should be at the beck and call of your customers family time pah the customer is always right!!!! Or so mine sometimes tell me π
Post by midlifecrisisrd on Jun 2, 2019 16:38:48 GMT 1
I half understand as Sunday is a religious day
But then we worship the two stroke God's so I consider it a cardinal sin that this place of worship is not open to it's faithful followers and the reverend mutts of nuts is not preaching on this holy day
On the day of reckoning thou shalt be punished for these crimes against humanity π€£π€£π€£
You will have to repent your sins and say 1000 hail seizures π
Post by veg on Jun 2, 2019 16:55:26 GMT 1
What would you know heathen? You blaspheme constantly with your talk of false idols your worship at the altar of the disciple he who you call power valve. Their can only be one true and original king sinner
Post by midlifecrisisrd on Jun 2, 2019 16:58:21 GMT 1
What would you know heathen? You blaspheme constantly with your talk of false idols your worship at the altar of the disciple he who you call power valve. Their can only be one true and original king sinner LC - old testament YPVS - new testament Need I say more π Steve
Post by Tobyjugs on Jun 2, 2019 17:06:17 GMT 1
What would you know heathen? You blaspheme constantly with your talk of false idols your worship at the altar of the disciple he who you call power valve. Their can only be one true and original king sinner That's it Veg keep the pressure on. There are not so many big bore kits with power valves.
Post by veg on Jun 2, 2019 17:09:06 GMT 1
Old = original New = usurper Every abrahamic faith is based on the βoriginal testamentβ Yours is based on the preachings of a Middle Eastern hippie aka the first βhipsterβ
Post by rigga on Jun 2, 2019 17:13:43 GMT 1
Old = original New = usurper Every abrahamic faith is based on the βoriginal testamentβ Yours is based on the preachings of a Middle Eastern hippie aka the first βhipsterβ Never thought id see the term "Hipster " mentioned on here ......
Post by midlifecrisisrd on Jun 2, 2019 17:21:29 GMT 1
Old = original New = usurper Every abrahamic faith is based on the βoriginal testamentβ Yours is based on the preachings of a Middle Eastern hippie aka the first βhipsterβ In my head as soon as you hit reply with that "hipster" comment there was a clap of thunder and a flash of lightening and now you have black smouldering hair Every cloud and all that π Going against religion I'm now going with Darwin and the evolution theory Evolving and improving with each generation π Steve
Post by veg on Jun 2, 2019 17:24:17 GMT 1
Ok so did the 350 motor used so successfully in the banshee retain or delete the power valves? And as you well know you b*****d I have no hair talk about hitting below the belt. Actually that is a good thing as a baldy I have evolved ala Darwin away from the apes and no longer need hair. I have also evolved so that I can stand more than 2 minutes sunshine unlike certain pasty faced individuals.
Post by midlifecrisisrd on Jun 2, 2019 17:29:08 GMT 1
Ok so did the 350 motor used so successfully in the banshee retain or delete the power valves? Ah but that's the same as a lot of things The make a mental bike then realise they have a duty of care so then detune/restrict it to save wimps from hurting them selves π Steve
Post by veg on Jun 2, 2019 17:31:42 GMT 1
Ok so did the 350 motor used so successfully in the banshee retain or delete the power valves? Ah but that's the same as a lot of things The make a mental bike then realise they have a duty of care so then detune/restrict it to save wimps from hurting them selves π Steve Exactly by smoothing out the power by fitting βpower valvesβ as some struggles with the unadulterated power band of the original. I knew you would see reason. π
Post by veg on Jun 2, 2019 17:33:38 GMT 1
Therefore I ride the original but made into more of a mental animal by use of Tz barrels whilst you ride a βpower valveβ and even when you start to agree that the 4lo is far better looking etc you b*****dise it by fitting a βpower valveβ Therefore self proclaiming that you sir are a in your own words A Wimp
Post by Gitram on Jun 2, 2019 17:36:53 GMT 1
I'll hold yer coats...
Post by midlifecrisisrd on Jun 2, 2019 17:39:08 GMT 1
Therefore I ride the original but made into more of a mental animal by use of Tz barrels whilst you ride a βpower valveβ and even when you start to agree that the 4lo is far better looking etc you b*****dise it by fitting a βpower valveβ Therefore self proclaiming that you sir are a in your own words A Wimp I think if you look in the rebuilds section you will find that the masses agree with the fitment of a pv lump in an lc Your tz build would struggle in a race with Davros the leader of the daleks They both have the same issue... ...no bottom end π€£π€£π€£ Steve
Post by veg on Jun 2, 2019 17:40:45 GMT 1
Young man myself Steve and the bear are renowned for being the argumentative old t**ts sat in the corner stinking of piss, we also have a habit of having the same discussion ad infinitum . Generally we are ignored. π
Post by veg on Jun 2, 2019 17:42:43 GMT 1
Steven I have just spat my tea across the kitchen . You may have a point this time t**t π
Post by midlifecrisisrd on Jun 2, 2019 17:49:16 GMT 1
What would you know heathen? You blaspheme constantly with your talk of false idols your worship at the altar of the disciple he who you call power valve. Their can only be one true and original king sinner That's it Veg keep the pressure on. There are not so many big bore kits with power valves.Β Β People are too fearful of a big bore pv Who was it that made the big bore cylinders with the blade type exhaust valves I'd love to build one of those but fear the cost of it Steve
Post by midlifecrisisrd on Jun 2, 2019 18:54:48 GMT 1
Steven I have just spat my tea across the kitchen . You may have a point this time t**t π In all honesty one of my favourite owned bikes was my 750 turbo Try no bottom end and turbo lag Feckin loved it though π Steve
Post by Tobyjugs on Jun 2, 2019 19:35:52 GMT 1
I think peddrotzr has had some dealings with these cylinder, not 100% sure though.
Post by midlifecrisisrd on Jun 2, 2019 19:39:56 GMT 1
I think peddrotzr has had some dealings with these cylinder, not 100% sure though. I thought his 535 may have had them Steve
Post by Yogi on Jun 2, 2019 19:40:26 GMT 1
Young man myself Steve and the bear are renowned for being the argumentative old t**ts sat in the corner stinking of piss, we also have a habit of having the same discussion ad infinitum . Generally we are ignored. π I think I must of been cleaning my pissed soaked corduroys cos I missed this little Intellectual conflict of interests π€π€π§ If man hadnβt stopped dragging his knuckles heβd never have invented power valves So I say viva the evolution ππ
Post by 0h5h1t on Jun 2, 2019 20:50:33 GMT 1
I had a viva once..... There was nothing evolved about it, believe me. π
Post by donkeychomp on Jun 2, 2019 21:59:27 GMT 1
Ok so did the 350 motor used so successfully in the banshee retain or delete the power valves? And as you well know you b*****d I have no hair talk about hitting below the belt. Actually that is a good thing as a baldy I have evolved ala Darwin away from the apes and no longer need hair. I have also evolved so that I can stand more than 2 minutes sunshine unlike certain pasty faced individuals. So now you can baldly go where no man has gone before... Alex
Post by madmick on Jun 3, 2019 11:07:19 GMT 1
You two are mad... crazy... but, extremely funny π π€£π€ͺ
M.M.
Post by muttsnuts on Jun 3, 2019 13:12:08 GMT 1
I had a viva once..... There was nothing evolved about it, believe me. π you aren't wrong there Karl, wonder how much they are worth today for one still in one piece, I nearly typed "good condition" but they weren't even like that from new !
Post by muttsnuts on Jun 3, 2019 13:12:54 GMT 1
and I am still closed on Sunday's despite all of the above ^^^^^^^ also closed on Saturdays now except by prior agreement/appointment
Post by midlifecrisisrd on Jun 3, 2019 17:48:28 GMT 1
I had a viva once..... There was nothing evolved about it, believe me. π you aren't wrong there Karl, wonder how much they are worth today for one still in one piece, I nearly typed "good condition" but they weren't even like that from new ! That made me wonder so I searched eBay Name any ford and there are plenty for sale Not surprisingly there is not even 1 viva for sale Steve
