Post by tsa on May 23, 2019 14:27:13 GMT 1
I need 2 measurements if you can please 1 is on a YPVS and its from the centre of the exhaust manifold to the centre of the rear bracket mounting hole only for aftermarket pipes please. 2 is on an LC and its from the centre of the exhaust manifold to the centre of the rear bracket mounting hole only for aftermarket pipes please. Please see pic below for details.
Post by shaunthe2nd on May 23, 2019 14:38:07 GMT 1
As best I can measure its about 660-663mm for a 250/350LC. I checked 3 different exhausts and all differ slightly.
Post by tsa on May 23, 2019 16:37:40 GMT 1
Cheers was that the pipe or the pipe and fitted manifold
Post by shaunthe2nd on May 23, 2019 16:41:51 GMT 1
Cheers was that the pipe or the pipe and fitted manifold It was based on a standard cigar pipe including the end flange.
