Post by souce on May 23, 2019 10:41:44 GMT 1
Hello everyone i’m Having troubles with my bike. It was running smooth when it suddenly stopped and didn’t restart. I can’t get a spark since then. I checked the connection and measured the resistance of the stator wiring. This is wat I found: - brown/black 241 ohms; - red/ brown 6.4 ohms; - white and red / black 91.4. According to the values I founds they should be ok. Checked the ignition coli and it’s ok ( high and low voltage). So now I really suspect a faulty CDI. Any suggestion would be appreciated before I buy a replacement. Found a tread where someone “added” an earth and solved a similar problem. What does it mean exactly? Many thanks, Ugo.
Post by kostas on May 23, 2019 15:18:19 GMT 1
Check ignition switch Also check the kill switch
Kostas
Post by midlifecrisisrd on May 23, 2019 15:44:50 GMT 1
If it's an 83/84 31k lc2 it's most likely the cdi
Well known for it
Post by zig on Sept 27, 2019 20:51:29 GMT 1
Hello everyone i’m Having troubles with my bike. It was running smooth when it suddenly stopped and didn’t restart. I can’t get a spark since then. I checked the connection and measured the resistance of the stator wiring. This is wat I found: - brown/black 241 ohms; - red/ brown 6.4 ohms; - white and red / black 91.4. According to the values I founds they should be ok. Checked the ignition coli and it’s ok ( high and low voltage). So now I really suspect a faulty CDI. Any suggestion would be appreciated before I buy a replacement. Found a tread where someone “added” an earth and solved a similar problem. What does it mean exactly? Many thanks, Ugo. did you ever find out the problem...i seem to have a similar problem with my 250lc ZiG
allan
Post by allan on Sept 30, 2019 14:06:14 GMT 1
id check the ignition barrel, kill switch and side stand switch. if its none of those then check ignition system starting with the pulse sensors and work my way up the system, checking values, and also checking all the connectors are actually connected. sometimes even though they are plugged in fully, the wire terminals inside arent actually connected, or barely connected and have come loose through vibration of riding all day.
