Post by crm on May 15, 2019 13:34:11 GMT 1
I rode my Mk3 for the first time in a while last night and by god it felt flat. Fresh 99 fuel and it still felt flat low down - far worse than i remember. I am going to check the compression - any idea where it should ideally be ? Its a Mk3 full power working YPVS
Once it hits 8k it does seem to fly along. it does seem very rich and lethargic though. not willing to rev and pulling out of a jcn is pretty dangerous.
Post by steven on May 15, 2019 17:38:24 GMT 1
Hi, If you know what the comression ratio is on your "MK3" you should be able to work out what the compression pressure should be. Here is an old post about a 250 lc, use the same formula for your MK3 once you find out what the compression ratio is. steven. rdlccrazy.proboards.com/thread/12394/rd-lc-250-compression
Post by mellow on May 16, 2019 16:57:42 GMT 1
are you sure the ypvs valve is working or fitted correctly?
Post by crm on May 24, 2019 20:26:46 GMT 1
it whirs as normal when the ignition is cycled and does seem to kick far better at 7k i will remove the end cap and cycle again to check its actually moving
