doink
Post by doink on Apr 24, 2019 2:50:08 GMT 1
What do these offer over the standard cdi etc? My 350 ypvs motor is fully standard bar some filters
Any power gains etc?
Post by ianboom on Apr 24, 2019 6:50:03 GMT 1
First thing that comes to mind is that if you buy the correct unit, you can change the powervalve opening times to get a bit more power. You can also change ignition advance, not sure what difference it will make to stock, but may be worth a small amount.
Ian
Post by stusco on Apr 24, 2019 7:26:16 GMT 1
It also replaces the thirty odd year old cdi that were known to be dodgy when new (31k) only down side IMO is having to chop the loom
Post by JonW on Apr 24, 2019 13:27:20 GMT 1
you can run wires to the original connectors so you dont cut your bike's loom, I do that on mine.
doink
Post by doink on Apr 25, 2019 1:52:52 GMT 1
Mines the 31k stuff, so maybe worth buying to get rid of all the old stuff then?
Post by stusco on Apr 25, 2019 7:11:12 GMT 1
I’m in the process of buying a zeel for my rg and it comes with the correct connectors already
Post by jackjabba on Apr 25, 2019 8:27:25 GMT 1
I noticed a better spark once fitted, easier starting. Make sure you use the correct diagram when you fit it, otherwise it wont start.
