Post by spooch63 on Apr 22, 2019 20:39:15 GMT 1
Hi,
I need to line a petrol tank but its 4 litre's at most. Does anyone know of a lining kit for the smaller tank. Looked on ebay and the usual places but can't find anything.
Cheers
Spooch
Post by Trent on Apr 23, 2019 9:44:37 GMT 1
Hi There, Had to restore a tank before that had the shit Kreem liner in it. Managed to get rid of the Kreem by using Acetone. After researching many avenues I tried Caswell coating. It reminds me of the coating used in aircraft fuel tanks and was easy to apply. Looks good 8 years later as it did when I first done it. Also had a tank painted and they used Caswell, even colored it to match the tank. Really recommend this liner. Hope this helps Trent
Post by raven13 on Apr 23, 2019 11:49:34 GMT 1
we only ever use flowliner at the garage, I'm sure the containers are resealable so you can measure out a smaller amount. I think it even gives the mixture ratio. Leaves you some for doing another tank later in life
Post by abar121 on Apr 23, 2019 12:24:42 GMT 1
I had a tank that was lined with a transparent liner. Looked like a good job and held up for ages.
Any idea what it was?
Post by midlifecrisisrd on Apr 23, 2019 15:13:57 GMT 1
I had a tank that was lined with a transparent liner. Looked like a good job and held up for ages. Any idea what it was? Slosh is clear Steve
Post by midlifecrisisrd on Apr 23, 2019 15:16:41 GMT 1
Flowliner states a 100 to 25 ratio if mixing small amounts
Like the look of this as a proper 2 part resin, not air activated
Also he is as it sets so tells you to coat the inside of the tank then stand on one end before rotating to recoat again then stand again so nice and thick coating
Post by shaunthe2nd on Apr 23, 2019 16:27:55 GMT 1
I had a tank that was lined with a transparent liner. Looked like a good job and held up for ages. Any idea what it was? Could be Tank Cure by LB Restoration. Very good stuff in my opinion.
Post by abar121 on Apr 23, 2019 17:47:42 GMT 1
Cheers chaps.
Post by spooch63 on Apr 23, 2019 21:21:37 GMT 1
Cheers guys,
Flowliner looks like the way yo go as I have a few of these tanks to do but only want to do one at a time.
Spooch
