Post by Yogi on Aug 21, 2019 17:15:21 GMT 1
Itβs lovely in Clackers π₯΅
What happened to Bonny Scotland π₯΄
Matt π»
Post by midlifecrisisrd on Aug 21, 2019 17:46:45 GMT 1
Not so feckin bonnie the last few days π§π±πΆ
Post by midlifecrisisrd on Aug 22, 2019 21:48:18 GMT 1
Post by midlifecrisisrd on Aug 22, 2019 21:50:29 GMT 1
Locks were mismatched so picked up an F2 set with the fuel cap missing cheap (using a billet one) so seat locks and helmet holder fitted. Need to swap the wiring over on the ignition switch as the plugs are different Steve
Post by midlifecrisisrd on Aug 22, 2019 22:23:34 GMT 1
New coil and plug caps Steve
Post by oldbritguy on Aug 22, 2019 23:20:34 GMT 1
Coming on great Steve
This is going to be another stunner even though you said at the beginning that it was just going to be a "tidy up" - Aye right!
John
Post by midlifecrisisrd on Aug 23, 2019 10:57:51 GMT 1
Coming on great Steve This is going to be another stunner even though you said at the beginning that it was just going to be a "tidy up" - Aye right! John Lol, Its difficult but there are bits I wouldn't just have bolted onto a "mint" build Engine not painted, just touched up and rad went on as it was. It will still be a really nice bike but will probably just sell after its registered to fund the next project. Found a guy with a GT750 frame with v5, Engine and hubs. Just got to persuade him to part with it π€£ Steve
Post by midlifecrisisrd on Aug 23, 2019 20:02:04 GMT 1
Throttle cables, rh switchgear, new grips and bar ends fitted Steve
Post by midlifecrisisrd on Aug 23, 2019 20:03:08 GMT 1
Electric plate, fuse box, horn and indicator relay on now Steve
Post by midlifecrisisrd on Sept 4, 2019 20:51:38 GMT 1
CDI fitted and wired up Steve
Post by midlifecrisisrd on Sept 4, 2019 20:55:05 GMT 1
And finally got the rear light/number plate holder to sit straight. I knew the light bracket was twisted but for the life of me it wouldn't sit right. Turns out the rear frame rail measurement from the spindle was 3mm out between them so rails were twisted A couple of tubes up the rear rails and a 6ft bar soon straightened it out Steve
Post by midlifecrisisrd on Sept 4, 2019 20:55:50 GMT 1
Front indicators fitted Steve
Post by midlifecrisisrd on Sept 4, 2019 20:57:58 GMT 1
Next was the front muddy The brace was a mess but managed to clean it up with a flap wheel then scotchbrited Bolted to freshly painted muddy and new Speedo cable guide Steve
Post by midlifecrisisrd on Sept 4, 2019 20:59:00 GMT 1
Next was the "arrow" refurbed pump and new lines Steve
Post by oldbritguy on Sept 4, 2019 22:35:39 GMT 1
You are charging on there Steve
Lovely jubbly
John
Post by midlifecrisisrd on Sept 11, 2019 19:50:45 GMT 1
It now has brakes - woohoo! Complete with 90's colourful lines π Headlight made up and fitted too, just waiting on a push in side light holder as the jap ones don't have it Steve
Post by midlifecrisisrd on Sept 11, 2019 19:55:42 GMT 1
Checked the sprocket alignment with the laser and all good there. Tightened the sprocket up and fitted the cover Steve
Post by dusty350 on Sept 11, 2019 20:08:43 GMT 1
Looking good Steve I do like the frame colour Dusty
Post by midlifecrisisrd on Sept 11, 2019 20:18:49 GMT 1
Looking good Steve I do like the frame colour Dusty Cheers Dusty, on the home straight now thankfully As for the frame colour I'm regretting getting my other frame done black now I've had some wheels done in the same colour which are going on the black frame. It would have been nice all in the titanium Steve
Post by midlifecrisisrd on Sept 12, 2019 21:05:05 GMT 1
Filled with fluids tonight and primed the oil pump. Only thing stopping me getting it fired up now is pipes. I'd given the chambers a quick rub down and painted black a few weeks ago but the cans were shabby. Both had burnt on stickers that needed soaked over night in DCM to remove and one had a loose end cap and rattled so drilled the rivets out and took apart. The baffle had broken at a weld so got that repaired easy enough. Biggest issue was the holes in the end cap were ovalled so would most likely loosen again. Came up with the idea of bonding m5 washers with silicone on the inside and using 12mm long rivets to go right through and pull it all together. Scotchbrited the cans and repacked them and riveted up then fitted to the pipes. Steve
Post by midlifecrisisrd on Sept 17, 2019 16:51:56 GMT 1
Got a few jobs done over the last few days Got the 10w bulbs to make the indy's flash. Thought it easier than trying to find another relay that suited Replaced a tail light bulb that was out and drilled the headlight to fit a pilot bulb as the Jap's have none. Also got the pipes fitted. The headers actually have 2 o rings in them that seal onto the stubs. Steve
Post by urbantangleweed on Sept 20, 2019 20:19:59 GMT 1
Nice work there mate. Mines all but done, nowhere near the standard of yours though. Waiting for Yamaha to ring me for the dating letter payment then I'll MOT her and start to get her registered.
Post by midlifecrisisrd on Sept 24, 2019 13:34:45 GMT 1
Well it lives...
....but rough as f*ck
Carbs overflowed first then drank 700ml of fuel in 10 mins so something way wrong
Choke makes it worse so wayyyy rich
Think the float levels are too high and it's flooding the crank cases as one down pipe has petrol running down it and the tail pipe on the other is very wet
Carbs are a bitch to come off as well
Post by urbantangleweed on Sept 24, 2019 16:38:34 GMT 1
Well it lives... ....but rough as f*ck Carbs overflowed first then drank 700ml of fuel in 10 mins so something way wrong Choke makes it worse so wayyyy rich Think the float levels are too high and it's flooding the crank cases as one down pipe has petrol running down it and the tail pipe on the other is very wet Carbs are a bitch to come off as well Steve Bugger!
Post by Tobyjugs on Sept 24, 2019 23:34:20 GMT 1
All part of the work. The good thing is your on the ball which means it will get sorted and not punted on as a total rebuild and its perfect with blah blah blah.
Post by JonW on Sept 25, 2019 13:39:23 GMT 1
Good work Steve!
Post by oldbritguy on Sept 25, 2019 15:44:45 GMT 1
Cracking job Steve Hopefully it is nothing more than a sticky float valve or as you say float heights which are a piece of p*ss for a man of your caliber Just a pity those carbs are a little tricky to get out All part of the fun
Post by midlifecrisisrd on Sept 25, 2019 17:28:06 GMT 1
Had them in bits now
Float levels seemed fine at 21mm but I've went to 22 to see how that affects it
I changed the valves and seats and i had to bend the tabs quite a bit to get 21mm. I really should have checked the before reading.
They did stop leaking after tapping the bowls so that point may have caused the flooding. Time will tell
Think I've mastered getting the carbs off now. Removal of the airbox rubbers first let's them come off easier, just the push pull cables are a pain.
After I wasn't finding anything wrong I drilled the brass balls out to check
Post by midlifecrisisrd on Sept 25, 2019 17:29:09 GMT 1
Behind my baws Steve
Post by Yogi on Sept 25, 2019 18:54:35 GMT 1
If youβve got shit behind your balls,, you need to take more care when wiping your arse ππ€£π€£π€£
