Post by twostroker on Mar 30, 2019 10:50:33 GMT 1
My mk3 125lc is a Swiss import so has the steering lock on the head stock but sadly it never came with the key. Is it possible to buy a key for the lock or remove the barrel and replace with another barrel and key?
Post by mellow on Mar 30, 2019 11:24:30 GMT 1
Lol I'm on same subject right now myself 😁👍
Post by twostroker on Mar 31, 2019 8:05:46 GMT 1
Lol I'm on same subject right now myself 😁👍 Let me know if you win Someone did suggest to me that the lock looks similar to a air/cooled lock so that’s a possibility
Post by Yogi on Mar 31, 2019 8:18:24 GMT 1
Don’t know for sure on 125s but on the 350 Swiss model I used a 4mm drill bit and drilled the barrel at 2 o’clock where the locking pin is located
Good luck Matt
Post by Yogi on Mar 31, 2019 8:21:58 GMT 1
Post by earthman on Mar 31, 2019 9:56:47 GMT 1
Welding on a couple of tabs and using a traditional UK style ignition lock, could that be an option on this model?
I know it is for the 4LO, yes it's a lot of work but if you plan on stripping the bike at some point???
Post by twostroker on Mar 31, 2019 12:32:15 GMT 1
Welding on a couple of tabs and using a traditional UK style ignition lock, could that be an option on this model? I know it is for the 4LO, yes it's a lot of work but if you plan on stripping the bike at some point??? I did think of welding tabs on the frame and making it uk spec. Thing is the bike would them become a ornament that I wouldn’t use if I stripped it and made it mint. It’s currently 8/10 condition wise and fully on the road so don’t want to do anything major to it ( yet)
Post by earthman on Mar 31, 2019 15:47:46 GMT 1
Welding on a couple of tabs and using a traditional UK style ignition lock, could that be an option on this model? I know it is for the 4LO, yes it's a lot of work but if you plan on stripping the bike at some point??? I did think of welding tabs on the frame and making it uk spec. Thing is the bike would them become a ornament that I wouldn’t use if I stripped it and made it mint. It’s currently 8/10 condition wise and fully on the road so don’t want to do anything major to it ( yet) I totally agree about not turning it into an ornament/not using it but things don't have to go that way. Make it the best you can though.
Post by Shytalk on Mar 31, 2019 20:27:15 GMT 1
My mk3 125lc is a Swiss import so has the steering lock on the head stock but sadly it never came with the key. Is it possible to buy a key for the lock or remove the barrel and replace with another barrel and key? You can buy the locks, I have got some for the LC350, it could well be the same part used, the only way to get the old one out is to drill down the central keyway, don’t go too far, keep the spring that sits behind the barrel too, have a look at the profile of the end piece and the overall length as that will determine what to get as a replacement.
