Post by veg on Mar 14, 2019 20:19:01 GMT 1
That is all.
Post by midlifecrisisrd on Mar 14, 2019 20:43:10 GMT 1
Oh, oh
What's happened
Post by veg on Mar 14, 2019 20:52:46 GMT 1
Tz top end not such a cracking idea with tz race pipes my dreams of pissing all over you pv jockeys appear to be just that dreams.
Post by Yogi on Mar 14, 2019 21:13:03 GMT 1
Come over from the dark side
Post by midlifecrisisrd on Mar 14, 2019 21:20:20 GMT 1
That's a right p1sser mate, must be gutted
Would Dave's pipes move the power much lower down the revs?
Or would it still be narrow?
Instead of a total loss and changing to ypvs could you not do some damage limitation and just use an LC top end?
Post by dusty350 on Mar 14, 2019 21:32:48 GMT 1
Trubrit has done the Tz top end - what set up does he use - pipes wise ? As the bike is already with Guru Dave, I would see what he can come up with. If anyone can sort it, Mutts is yer man ! Dusty
Post by 4l04ever on Mar 14, 2019 22:11:25 GMT 1
TZ700 porting is very close to LC porting, so must be the pipes causing the power characteristics. You could look at modifying the original TZ pipes. They would need to be made longer to get the revs down.
Post by veg on Mar 14, 2019 22:32:39 GMT 1
Thanks rob I have said to Dave I will probably put miles on it then get him to make some pipes. He said exactly that that the tz pipes are too short. It is all top end at 9000 plus rpm which will be unrideable been great when I was 18 not so good at 49.
Post by veg on Mar 14, 2019 22:36:27 GMT 1
Dusty, Dave has said it needs miles it’s really a smaller set back and a 1st world problem but I’m desperate to get some miles on it. Knowing what I know now would I have bothered nope I would have gone pv (yes Steve and Matt you heard it) or even big bore . Is it unique yep is there a reason for that probably has the motor alone cost me more than a decent big bore motor yep. Live and learn.
Post by 4l04ever on Mar 14, 2019 22:37:43 GMT 1
I just double checked the default port maps. Top of exhaust is higher than I remember on the TZ750 port map. 26.5mm from top. LC is only 30mm. Higher the exhaust port, higher the revs for peak power :-(
Maybe speak to Kenny (TSA) to see if he can design some exhausts to bring it down.
One other option is to put liners in the TZ cylinder block and have them ported to match LC. This is what I was planning to do with my TZ so it looks like a TZ, but rides line an LC.
Post by 4l04ever on Mar 14, 2019 22:44:26 GMT 1
Tz750 map
Post by 4l04ever on Mar 14, 2019 22:45:05 GMT 1
LC port map
Post by veg on Mar 14, 2019 22:46:06 GMT 1
Do you have a 700 one rob as Dave needs one for the pipes. Or can you point me in the direction of where I can get one? Cheers
Post by Yogi on Mar 14, 2019 22:54:58 GMT 1
Gutted for you mate but I’m sure you’ll get it sorted
Sounds like pipes are the way to go so it’s not all lost
Matt
Post by 4l04ever on Mar 14, 2019 23:01:52 GMT 1
Not got one, so would need to get a cylinder measured up. The cylinder I have is a modified TZ750 one.
Post by 4l04ever on Mar 14, 2019 23:04:20 GMT 1
If you could have skimmed 2mm of the bottom of your cylinders and reprofiled the head, that could have worked, but would be nearly impossible to do on monoblock type cylinders :-(
Post by oldelsieboy on Mar 14, 2019 23:08:36 GMT 1
Do you have a 700 one rob as Dave needs one for the pipes. Or can you point me in the direction of where I can get one? Cheers Tim, AFAIK the 700 & 750 port maps are the same, the only difference is the bore size, 64mm - 66.4mm OEB
Post by midlifecrisisrd on Mar 14, 2019 23:09:36 GMT 1
Would a stroker crank and a modified head help
Would that not help with the high exhaust port
Either that are skim the cases, not the barrel
Post by 4l04ever on Mar 14, 2019 23:15:19 GMT 1
Post by oldelsieboy on Mar 14, 2019 23:17:23 GMT 1
Yup. OEB
Post by 4l04ever on Mar 14, 2019 23:22:54 GMT 1
Would a stroker crank and a modified head help Would that not help with the high exhaust port Either that are skim the cases, not the barrel Steve Norbo has some 4mm stroker cranks for LCs in the pipeline... that could work too, and gain power...
Post by Tobyjugs on Mar 15, 2019 0:59:13 GMT 1
Those ports maps make a lot of difference to the performance Rob. I would go the +4 route. You might even be able to use the TZ set up with the head modified to suit.
Powervalves PAAHH!!!
Post by veg on Mar 15, 2019 6:48:24 GMT 1
Chaps thanks for all the advice guidance and support. I was a bit disappointed. That’s all it’s a real first world problem and I am thankful for everything else that I have. I am going to persevere with this I have too much invested to just give up and walk away and will get some miles on it then back to Dave’s for pipes. Cheers again for all the help and messages.
Post by headcoats on Mar 15, 2019 9:31:24 GMT 1
Did you get a dynograph of it
Post by veg on Mar 15, 2019 9:56:44 GMT 1
Nope it’s coming in with such force the new clutch is slipping and as Dave said he doesn’t really want to start spinning up a new crank rings and nickasil liners without any miles in them
Post by muttsnuts on Mar 15, 2019 10:38:09 GMT 1
yeah, its very peaky, just fixing the clutch this morning and then map and fuel the bottom end to allow some miles to be put on it
Its not all bad, just flat low down, the very short TZ pipes are fine for big BP high up, but they are designed for the very high exhaust port (Rob is correct at 26.5), once Tim has got a few miles on the new engine it will come back and I'll design some new pipes for it, might even graft a set of mid range LC pipes on to see how it goes with them before spending time and money designing a new set, they should bring the rpm and power back down
If it was a track bike and Tim didn't care about swapping the crank out a few times a year then it would be great, but peak power looks to be set to come in around 10500rpm or higher, which is not really much use on the road in this day and age
I can sort it, just down to what Tim wants from it, it should do good power with the right set of pipes on it
Post by midlifecrisisrd on Mar 15, 2019 11:07:14 GMT 1
I was going to suggest bridging a set of "normal" spannies on to see how it runs even if just to put the miles on
Dave already on it though 😉
Post by veg on Mar 15, 2019 12:12:19 GMT 1
That’s why Dave’s the man he knows his shite.
