Post by pdxjim on Mar 7, 2019 1:14:31 GMT 1
Forgive me, as I've beat the search function to death on this one and not yet come up with a definitive answer. Looking to do 520 chain conversion on my LC. Looks like RZ sprocket sorts the front, but what is the easy route on the rear? And yes, I'm in the states which doesn't help things. shop.pbisprockets.com/ is right down the road from me, but unfortunately they don't even stock standard 530 rears for the LC. Is there a rear off another bike that will fit the LC wheel? 530 or 520 doesn't matter as I can have them turn it down to 520 for me if needed. Help plz.
Post by tacky1 on Mar 7, 2019 1:49:03 GMT 1
I was in the same boat, I bought my rear sprocket from Norbo, I couldn’t find a similar sprocket
Post by pdxjim on Mar 7, 2019 2:21:46 GMT 1
I was in the same boat, I bought my rear sprocket from Norbo, I could find a similar sprocket I can only find steel 530 rears on Norbo's but it's entirely likely they're there and I'm missing them.
Post by tacky1 on Mar 7, 2019 5:27:02 GMT 1
Sorry, I edited my first post. Bloody phone. Contact him and he will sort you out. He doesn’t list them. Basically they cut back the sprocket to fit the 520 chain.
Post by pdxjim on Jun 10, 2019 21:41:19 GMT 1
Just spoke to Jim at PBI here in Portland, Oregon USA. shop.pbisprockets.com/main.scHe's quoted me "about 50 bucks" for a custom hard anodized aluminum 520 rear sprocket to fit the standard LC wheel. Anyone else interested in one while I'm at it?
Post by donkeychomp on Jun 10, 2019 23:11:15 GMT 1
Dammit! I thought someone had done a 520cc conversion kit!
Post by muttsnuts on Jun 11, 2019 8:56:25 GMT 1
I just make the rear sprocket up from a blank (but then I have the machines to do it !), 50 bucks doesn't sound too bad for a custom made sprocket TBH as it will take me at least an hour to modify a blank to fit, plus probably another hour of faffing getting the measurements etc all correct
Post by pdxjim on Jun 26, 2019 17:27:00 GMT 1
Post by JonW on Jun 28, 2019 1:02:27 GMT 1
Those look great Jim! Im tempted...
Post by Tobyjugs on Jun 28, 2019 2:42:07 GMT 1
They look fantastic
Post by pdxjim on Jun 28, 2019 3:19:36 GMT 1
Ally 520 sprox roughly 2lbs/.9kg lighter than standard.
Post by Tobyjugs on Jun 28, 2019 3:31:04 GMT 1
Much more effective than buying a few titanium bolts
I also noticed that steel cap head allen bolts are almost the same weight as a titanium hex bolts the same size.
Post by icarus001 on Jun 28, 2019 7:08:34 GMT 1
When I converted mine years ago I don't remember struggling for parts, from memory there are 520 sprockets for another bike that fit straight on. I'm sure I've actually got the part numbers written down at home but I'm working away at the moment. Might be from a race bike, I can't remember, my memory is knackered these days. Back before we all relied on ebay I used to know what part numbers from other bikes fitted on my LC, I could walk into a shop and just reel off the part number for a part off something like an XS650 that I knew would fit the LC - but now I rely on the internet to do everything for me For what it's worth I don't remember the 520 conversion making much difference - swapping out the wheels for lighter ones did though.
Post by pdxjim on Jun 28, 2019 16:14:53 GMT 1
For what it's worth I don't remember the 520 conversion making much difference - swapping out the wheels for lighter ones did though. As this bike will retain most of the stock road gear (turn indicators, center stand, grab bar, passenger pegs, etc, etc), I'm not overly concerned with critical weight savings. That said, if I'm going to be replacing the chain n' sprox anyway, I may as well shave a few lbs of rotating mass off and bling up a bit while I'm at it. 520 chain and drilled out race style c'shaft sprocket are quite a bit lighter as well and cost the same as the standard items.
Post by icarus001 on Jun 29, 2019 4:15:06 GMT 1
As this bike will retain most of the stock road gear (turn indicators, center stand, grab bar, passenger pegs, etc, etc), I'm not overly concerned with critical weight savings. That said, if I'm going to be replacing the chain n' sprox anyway, I may as well shave a few lbs of rotating mass off and bling up a bit while I'm at it. 520 chain and drilled out race style c'shaft sprocket are quite a bit lighter as well and cost the same as the standard items. I don't know about you but I'm a good 15kg heavier than I used to be when I was riding around on two strokes back in the day, so the easiest way for me to make a difference is to stay away from the fridge
Post by Tobyjugs on Jun 29, 2019 5:42:37 GMT 1
As this bike will retain most of the stock road gear (turn indicators, center stand, grab bar, passenger pegs, etc, etc), I'm not overly concerned with critical weight savings. That said, if I'm going to be replacing the chain n' sprox anyway, I may as well shave a few lbs of rotating mass off and bling up a bit while I'm at it. 520 chain and drilled out race style c'shaft sprocket are quite a bit lighter as well and cost the same as the standard items. I don't know about you but I'm a good 15kg heavier than I used to be when I was riding around on two strokes back in the day, so the easiest way for me to make a difference is to stay away from the fridge Ha Ha your not the only one.
Post by robin on Jun 29, 2019 18:53:40 GMT 1
I don't know about you but I'm a good 15kg heavier than I used to be when I was riding around on two strokes back in the day, so the easiest way for me to make a difference is to stay away from the fridge Ha Ha your not the only one. Given the choice to go on a diet or spend hours in the workshop making things a bit lighter, I know where I will be working, and a lot happier too! P.S. I already have a 520 conversion, when the rear disc was done, so pass me another packet of biscuits over.
Post by raven13 on Jun 29, 2019 19:15:25 GMT 1
As this bike will retain most of the stock road gear (turn indicators, center stand, grab bar, passenger pegs, etc, etc), I'm not overly concerned with critical weight savings. That said, if I'm going to be replacing the chain n' sprox anyway, I may as well shave a few lbs of rotating mass off and bling up a bit while I'm at it. 520 chain and drilled out race style c'shaft sprocket are quite a bit lighter as well and cost the same as the standard items. I don't know about you but I'm a good 15kg heavier than I used to be when I was riding around on two strokes back in the day, so the easiest way for me to make a difference is to stay away from the fridge wish it was only 15kg
Post by Tobyjugs on Jun 30, 2019 0:39:34 GMT 1
I wonder how long it takes to wear the sprocket out?
Post by pdxjim on Jun 30, 2019 1:10:32 GMT 1
I wonder how long it takes to wear the sprocket out? I have had them last quite a long time in the past. Well suited for a 2T twin. V-twin 4T or big single, notsomuch
