Post by jazzyjembreaze on Feb 26, 2019 17:34:41 GMT 1
Anyone got any pics of a mk2 headstock config ( not the diagram from a manual ), It’s just I’ve got several size top and bottom race and I need to know wich one is correct Pretty sure this is the bottom race as fits perfect however bought some bearings from Norbo and it doesn’t sit proud on the race Am I right in thinking ( wrong bearing )
Post by jazzyjembreaze on Feb 26, 2019 17:39:21 GMT 1
I figured on these been the correct components If I’m wrong please advise Left to right Bottom race / top race / top cover and screw nut
Post by mellow on Feb 26, 2019 17:39:44 GMT 1
don't quote me but that's a taper bearing, so i think the plain washer bit is not needed. probably wrong, im sure someone will put me right soon
Post by jazzyjembreaze on Feb 26, 2019 17:45:44 GMT 1
Really , do you don’t use the race ? I’d always assume esp the bottom race to be a protection plate and grease cover / I know on my Fireblade they still have them / albeit they are very thin and almost tin like but they have a lip to protect the bearing from foreign body and grime . These are very thick on the RD , maybe your right mellow , but the bearing def does not sit proud on it
Post by mellow on Feb 26, 2019 18:03:07 GMT 1
like i say not 100% sure but i thought the rubber seal sits on lower yoke, then bearing sits on that and the conical seat fits into frame. Then the top one has conical bit into headstock then bearing into that then the cover and nut. Someone will clarify for sure
Post by jazzyjembreaze on Feb 26, 2019 18:19:55 GMT 1
Ok , I’m missing the rubber seal then Where do I get one ?
Post by jazzyjembreaze on Feb 26, 2019 18:24:29 GMT 1
Top to bottom Screw Screw nut Cover Tapered bearing Conical Conical Tapered bearing ( missing rubber seal then ? flic.kr/p/2dQLpow
Post by mellow on Feb 26, 2019 20:07:06 GMT 1
Cant u use the seal that was under old race?
Post by jazzyjembreaze on Feb 26, 2019 23:05:07 GMT 1
It didn’t have one on Mellow on dis assembly This bike was a bit pita remember ( lots missing and things changed for non LC items etc
Post by mellow on Feb 27, 2019 10:32:49 GMT 1
I might have one on a stem down shed. Will look when I get 5 mins if you want.
Post by jazzyjembreaze on Feb 27, 2019 12:04:58 GMT 1
Very kind of you thanks 👍
Post by mellow on Mar 1, 2019 15:58:21 GMT 1
Hi Mate. sorry took a while, been busy. Checked an old stem and a NOS one i have and neither have a rubber seal so i guess it doesn't have one there and that's why parts fiche doesn't show one
Post by jazzyjembreaze on Mar 1, 2019 22:18:42 GMT 1
Thanks for looking I'll fabricate something just to add as a dust seal
