Post by mellow on Dec 20, 2018 19:52:17 GMT 1
I'm sure a few of you are watching THISThe seller may even be on here. But what i'm struggling with is if this needs the extra bracket i'm guessing it's not for an RD125LC?
Post by jazzyjembreaze on Dec 20, 2018 20:50:01 GMT 1
I don’t think it’s from a 125 LC The mid section is at the wrong angle so if that bracket were not attached it wouldn’t be able to reach the hanger
Post by mellow on Dec 20, 2018 23:41:15 GMT 1
Must be close to belly pan too🙄
Post by raven13 on Dec 21, 2018 0:13:41 GMT 1
if its for the rd125lc it should fit that bracket easily. everything about the pipe looks right. I wonder if its been bent where the header meets the expansion chamber. that would account for the poor fit, as it looks like the original bracket will make it to the hole .
Post by jazzyjembreaze on Dec 21, 2018 0:52:19 GMT 1
Poss the header down pipe has been replaced & re welded at some point with a re chrome .. Just a thought /
Post by brucie on Dec 21, 2018 12:56:03 GMT 1
It's the right pipe for the bike i have got the same micron on my bike what that extra bit is i have no idea because it will fit without it and is close to the hanger I'm guessing it will probably go for around 500 pounds
Post by bertiemollie on Dec 23, 2018 14:40:18 GMT 1
I have a Micron similar to this but I have the alloy end can. It lines up perfectly at the hanger hole.
It could be for something else like and NS125 or RG, AR. I know an NS125F has the same barrel fitment but doesn't line up at the back.
