Post by jazzyjembreaze on Nov 29, 2018 16:47:24 GMT 1
Hi everyone , just saying hello as a new member , just purchased a mk2 125lc yesterday for restoration . My story , I'm 50 in 4 weeks in the 80's I owned 2 chappy red 125's the second was running a 180 barrel , I then got a 350 ypvs from a cousin , my two stroke story ended in the early 90's when I got into bigger bikes & thus all was forgot . Back of my mind I always wanted to revisit those times so thought I would start with the 125 . So picked up a bike that has been sat in a garage since 2009 , it has no rust but prior to it been stood up it was taken apart due to a blown engine / the guy painted the frame ( horrible blue ) then put another engine in & must of got bored with it . So it was left ... along I come looking for something totally different ( car related & spot this Mk2 wheel on a shelf ( I knew instantly what it was , anyway after a discussion & spending a hour digging bits out I realize there is indeed a 125 mk 2 I'd say with 85% of the bike there including a second engine . I made a offer to take it from his hands & he excepted .. it's gonna be a lot of hard work but I've done many projects & my plan is to get it back to concourse as close as I can . First job will be stripping it down & sorting what's what , I'm prob going to start with the engine , getting the cases vapour blasted & starting the engine rebuild from the ground up . I'm sure I will have a ton of questions to ask as I progress , but for now thanks for reading kind regards mic
Post by dusty350 on Nov 29, 2018 19:35:51 GMT 1
Hi Welcome to the forum. Sounds like a great project. Lots of help on the forum, and Norbo runs a shop linked to the forum where you can buy new parts. Get to 10 posts and you can access the classifieds too Enjoy Dusty
Post by oldbritguy on Nov 30, 2018 1:24:53 GMT 1
Welcome to the forum and don't be shy with any questions.
There is loads of experience and knowledge on here and a friendly willingness to help where possible.
As Dusty said, have a look in Norbo's shop for loads of new parts and watch your bank balance take a hit from all the goodies he has in stock but, most importantly, enjoy the restoration
John
Post by jazzyjembreaze on Nov 30, 2018 3:13:14 GMT 1
Thanks Dusty , thanks John , I will do ,
Post by jazzyjembreaze on Nov 30, 2018 13:05:57 GMT 1
Here’s a pic if I have done it right
Post by jazzyjembreaze on Nov 30, 2018 13:19:20 GMT 1
I know front wheel on wrong way round that’s how it stood , good points all the plastics have no tabs missing & the tank is rust free & no dents , so after a first look after getting it home from what I can see def has wrong carb on ( not even off a LC ) Parts missing Carb , airbox inlet rubber & air chamber , left footrest hanger , gear change arm , rear grab rail , took the clocks & headlight off last night wiring is bad so once I get it stripped I will look to see what the loom is like but it looks to be butchered with connectors missing here and there .clocks are very dusty but intact with no cracks . Odo reads 5660, prob spent most of its life with the Speedo drive unplugged , V5 states first registered 10,1986 , more to follow
Post by oldbritguy on Nov 30, 2018 18:17:22 GMT 1
Front forks on wrong way round so wheel might be on right lol! Looks an excellent starting point though and pretty clean too Enjoy the hunt
Post by jazzyjembreaze on Nov 30, 2018 19:02:18 GMT 1
Yea I know was just saying as you can see caliper & disk is on left / thanks for saying that , about good starting point , I will get some time on it soon to begin . My first spend will be a centre stand ( anyone got one ?) then I will get the frame painted & leave it as that whilst I strip & rebuild the engine to as new as I can get ( also need a carb , slide & air chamber + inlet if anyone can help , good condition but I will be getting the carb vapour blasted so if it’s just a bit grime that doesn’t matter . First important question What is the correct RAL code for the frame ? Second question As it’s a 1986 1GM bike that gives me 2 options Black or white I’m thinking white , what’s your thoughts Thanks again mic
Post by oldbritguy on Nov 30, 2018 19:59:22 GMT 1
As Dusty says get 10 posts on the forum and you have access to the classified section and stick up a wanted list. I am sure there are guys and gals on the forum will be able to help you out. Make some comments on other threads and you will get to ten no problem. As for RAL colour codes I am not sure but I will bet someone on here will. If it was up to me I'd go white Cheers John
Post by jazzyjembreaze on Nov 30, 2018 22:36:49 GMT 1
Thanks John , yes I’m goin to go white 👍
Post by jazzyjembreaze on Dec 1, 2018 0:39:35 GMT 1
Has a cruddy allspeed with it , I was never a allspeed guy back in the day , small can micron , hopefully I will be able to source one at some point .
Post by petenofear on Dec 1, 2018 20:57:55 GMT 1
In joy th rd mate
Allspeed for sale if so send me a pm
Post by jazzyjembreaze on Dec 9, 2018 13:32:19 GMT 1
Stripped it back Engine 1 Engine 2
Post by jazzyjembreaze on Dec 9, 2018 13:48:55 GMT 1
As I don’t know the paint codes ( RAL) & I don’t have a bike to look at for reference, been a MK2 Would you guys say the frame , arm , & triple clamp are Satin Matt Or Gloss Black Thanks in adv Mic
Post by mellow on Dec 9, 2018 16:45:23 GMT 1
Im saying gloss
Post by jazzyjembreaze on Dec 9, 2018 18:53:48 GMT 1
Thanks for reply mellow 👍
