Rg400
Jul 9, 2019 12:04:10 GMT 1
Post by Deleted on Jul 9, 2019 12:04:10 GMT 1
Just had a email my exhausts are on their way Fingers crossed :-)
Post by mouse on Jul 9, 2019 13:31:48 GMT 1
Just tried to fit my refurbed rear master cylinder guess what ! It doesn’t fit with the braced swingarm,the reservoir is touching the bracing 🤬do I need a back brake anyway! So far I’ve had to under sling the caliper to avoid the bracing now this I’ll bet M.D is just waiting on ordering his upgraded rear master cylinder for about £200. where do I get one of those poly hose reservoir? If you want the HRC hose kit, it comes wuith the stopper etc, the hose is green. Try 'Dobles' motorcycles or Fleabay Mouse
Post by stusco on Jul 10, 2019 15:25:42 GMT 1
They’re here I’m not a fan of the blue anodising I might have to get the oven cleaner out
Rg400
Jul 10, 2019 15:42:38 GMT 1
via mobile
Post by midlifecrisisrd on Jul 10, 2019 15:42:38 GMT 1
Rg400
Jul 10, 2019 22:36:53 GMT 1
Post by donkeychomp on Jul 10, 2019 22:36:53 GMT 1
Wow.
Rg400
Jul 11, 2019 0:03:35 GMT 1
Post by steven on Jul 11, 2019 0:03:35 GMT 1
Hi, Snazi lums, classic chib ! Steven.
richb
Post by richb on Jul 11, 2019 8:04:28 GMT 1
They are pretty well worth the wait even look sexy wrapped up in pvc sorry plastic protection.
Rg400
Jul 11, 2019 8:11:53 GMT 1
Post by dusty350 on Jul 11, 2019 8:11:53 GMT 1
They look stunning !! His welding is unbelievable. I remember seeing his Facebook page pics when he welded 2 beer cans together - genius ! They will look great once fitted. Dusty
Rg400
Jul 11, 2019 8:24:44 GMT 1
Post by Deleted on Jul 11, 2019 8:24:44 GMT 1
Nice one. Are they SS or mild steel which will flash rust if you sneeze on them. They will look beautiful as they are. Just fit them :-)
Rg400
Jul 11, 2019 13:54:40 GMT 1
Post by stusco on Jul 11, 2019 13:54:40 GMT 1
Nice one. Are they SS or mild steel which will flash rust if you sneeze on them. They will look beautiful as they are. Just fit them :-) Stainless steel ,I might fit them tonight
Rg400
Jul 12, 2019 7:02:22 GMT 1
Post by 17again on Jul 12, 2019 7:02:22 GMT 1
pipes look pretty nice.
who are they made by?
Rg400
Jul 12, 2019 7:11:03 GMT 1
Post by stusco on Jul 12, 2019 7:11:03 GMT 1
pipes look pretty nice. who are they made by? Mark Dent
Post by stusco on Jul 12, 2019 17:03:15 GMT 1
A view from the rear
Post by 17again on Jul 12, 2019 19:57:54 GMT 1
cans look nice and i like the fact the upper can are bigger.
Rg400
Jul 12, 2019 20:06:08 GMT 1
Post by stusco on Jul 12, 2019 20:06:08 GMT 1
It’s an optical illusion they are different lengths though
Rg400
Jul 13, 2019 16:42:37 GMT 1
Post by stusco on Jul 13, 2019 16:42:37 GMT 1
Fired it up today not without problems first of all my new zeel doesn’t work so fitted the original after going through all the electrics it fired up on three cylinders after a lot of faffing and after my helper left i checked the plug he said was sparking and it’s not sparking on #1 cylinder I’ll check the cap and lead tomorrow as I’m c**ted from kicking the high kick start
Rg400
Jul 13, 2019 16:49:58 GMT 1
Post by stusco on Jul 13, 2019 16:49:58 GMT 1
Another problem the pv cycles when I turn the ignition on I don’t think that’s right but it has a zeel pv so who knows! They don’t come with instructions just checked the zeel site it does a test cycle on power up
Rg400
Jul 13, 2019 17:26:04 GMT 1
Post by stusco on Jul 13, 2019 17:26:04 GMT 1
I’ll get video up when its running on all four
Rg400
Jul 14, 2019 14:04:49 GMT 1
Post by stusco on Jul 14, 2019 14:04:49 GMT 1
Here’s where I am it is sparking on #1 cylinder it has 115psi compression but it’s not drawing in the fuel I can put a tissue over the carb and it falls off !! The disc valve is open at the same time as it’s oppo so I don’t have that on wrong anyone got any advice? i did a pressure test on each pot they held 5psi for 5 mins
Post by stusco on Jul 15, 2019 16:02:38 GMT 1
Took the #1 carb off checked it out could find nothing wrong blew down all the pipes found something in the spigot on #3 carb possibly a blockage?put it all back together and it works runs on all cylinders www.dropbox.com/s/n9ws772wyrhcn60/IMG_0323.MOV?dl=0
Rg400
Jul 15, 2019 16:07:45 GMT 1
via mobile
Post by midlifecrisisrd on Jul 15, 2019 16:07:45 GMT 1
Happy days sir 😀
Rg400
Jul 15, 2019 18:11:34 GMT 1
Post by Mr Kipling on Jul 15, 2019 18:11:34 GMT 1
happy days indeed...coming along nicely...
Rg400
Jul 15, 2019 18:43:23 GMT 1
Post by dusty350 on Jul 15, 2019 18:43:23 GMT 1
Great news Glad it was a simple fix. Sounds very nice, and the pipes look fantastic Well done Dusty
Rg400
Jul 15, 2019 19:33:57 GMT 1
Post by 17again on Jul 15, 2019 19:33:57 GMT 1
looking and sounding nice stu.
Rg400
Jul 15, 2019 20:36:08 GMT 1
Post by tacky1 on Jul 15, 2019 20:36:08 GMT 1
Now that sounds and looks the biz
Post by steven on Jul 15, 2019 23:36:00 GMT 1
...sounds and looks great, and she husny even goat her claes oan yet ! Steven.
Post by stusco on Jul 18, 2019 15:44:31 GMT 1
What’s happening here
Rg400
Jul 18, 2019 18:58:18 GMT 1
Post by andy748 on Jul 18, 2019 18:58:18 GMT 1
Mine was exactly the same on my rgv, fitted a fireblade hose and it stopped sweating brake fluid, think it had a cheapo hose fitted at some point. Andy.
Rg400
Jul 18, 2019 19:27:48 GMT 1
Post by stusco on Jul 18, 2019 19:27:48 GMT 1
It’s a cheap Chinese reservoir and pipe I will need to change it😩
Post by stusco on Jul 27, 2019 11:14:32 GMT 1
