Post by midlifecrisisrd on Feb 5, 2019 15:43:05 GMT 1
What does the part look like? It's the little clips that hold the fuses. Like in a household plug Luckily I've just found 2. One even has the right coloured wiring lol Steve
Post by Tobyjugs on Feb 5, 2019 16:46:09 GMT 1
Ok i understand now.
Post by midlifecrisisrd on Feb 5, 2019 17:41:11 GMT 1
F uck
3rd one is loose too so need to change the box 😥
Post by midlifecrisisrd on Feb 5, 2019 18:48:19 GMT 1
Next disaster
The 9mm offset sprocket arrived
With the sprocket and ypvs spacer the chain want to run through the frame 🙁
Change spacer to one 5mm thinner and the chain "just" clears but the chain run is now out by about 4mm so looks like I need to machine the carrier down more
Post by marrcel on Feb 5, 2019 19:23:53 GMT 1
That is a good uportunity to go for flat mini fuses. 🤗
Post by marrcel on Feb 5, 2019 19:31:59 GMT 1
Question for you steve. Which fuse do you use for the igni? I used 10amps.
Post by Tobyjugs on Feb 5, 2019 19:34:21 GMT 1
I used 10 amps as well, for no other reason than it was the circuit i tapped the power from.
Post by midlifecrisisrd on Feb 5, 2019 19:52:32 GMT 1
That is a good uportunity to go for flat mini fuses. 🤗 I have ordered both a blade type 4 way fuse box and a replacement box. I'm using 10a too but 5a is plenty Steve
Post by midlifecrisisrd on Feb 7, 2019 17:45:19 GMT 1
£5 later and carrier has 5mm machined off 😁 Steve ![](https://uploads.tapatalk-cdn.com/20190207/aafbb865be4a0be9213f64a9e555e759.jpg)
Post by headcoats on Feb 7, 2019 18:41:17 GMT 1
Still looks sturdy
Post by philmill on Feb 7, 2019 19:25:27 GMT 1
God I wish I could like that something done that quickly..... So does it line up now?
Phil
Post by midlifecrisisrd on Feb 7, 2019 19:32:56 GMT 1
God I wish I could like that something done that quickly..... So does it line up now? Phil I'll tell you when the new SS sprocket bolts arrive 😉 He's a good old boy, usually turned around in a couple of days but surpassed himself today in 2 hours I laughed when he said it took longer than expected as it wouldn't fit in the lathe so he had to turn down a bit of nylon to fit in the jaws then sandwiched the carrier in to cut it down Steve
Post by midlifecrisisrd on Feb 13, 2019 14:46:54 GMT 1
Got the servo motor bolted in and fitted the new cables from Muttsnuts Fuse box repaired and feed for ignitech soldered in Need to get the battery fitted and find an lc wiring loom as got a bit of resistance between the tail light fuse and the battery. Typically that's the one I tapped the Ignitech feed to 🙄 Steve ![](https://uploads.tapatalk-cdn.com/20190213/a62555d338363eb10c7c7a5dd94244be.jpg) ![](https://uploads.tapatalk-cdn.com/20190213/f53e1416f5412f5acc8207e6b76ba736.jpg)
Post by philmill on Feb 13, 2019 15:43:23 GMT 1
Looks awesome Steve, I think I need to get my forks done too, they do look great having been redone..
Phil
Post by midlifecrisisrd on Feb 14, 2019 23:03:06 GMT 1
Got the battery in tonight so woohoo we have power Steve ![](https://uploads.tapatalk-cdn.com/20190214/bc6caa1f3322ab2f9371ca0b225e41fc.jpg) ![](https://uploads.tapatalk-cdn.com/20190214/5ac543bf9d382db54f1ec6044c937f11.jpg)
Post by midlifecrisisrd on Feb 14, 2019 23:04:43 GMT 1
Front sprocket finally torqued up and chain fitted Steve ![](https://uploads.tapatalk-cdn.com/20190214/c835e78fab015aebffefc9986dedfbaa.jpg)
Post by midlifecrisisrd on Feb 14, 2019 23:06:30 GMT 1
I'm calling it a night now. Front indicators fitted and working Bolted on the coil cover too Steve ![](https://uploads.tapatalk-cdn.com/20190214/fdd0bcddc32ce8457b768f8d86836c91.jpg) ![](https://uploads.tapatalk-cdn.com/20190214/ea8c87631cdce3b3cb39ebd69cccec7b.jpg) ![](https://uploads.tapatalk-cdn.com/20190214/caf7abbffb1bde710b81a2e389506417.jpg)
Post by oldbritguy on Feb 14, 2019 23:13:34 GMT 1
Looking absolutely amazing Steve. Well jealous!! John
Post by panzermatt on Feb 15, 2019 19:58:57 GMT 1
That is a class job, loving this thread, not enough pictures though. we want more!!
Post by philmill on Feb 15, 2019 20:53:20 GMT 1
Stunning, I love it, great work again Steve.
Phil
Post by midlifecrisisrd on Feb 21, 2019 19:51:25 GMT 1
Got the LH case fitted now. Was waiting on the 2 new dowels arriving but then when I first fitted it I noticed the gear change hole was sloppy so ordered a 14mm drill bit and a ypvs crankcase gear change shaft bush. Drilled out the case then fitted the bush. Nice fit now 😁 Steve ![](https://uploads.tapatalk-cdn.com/20190221/74bc02553c4d54bc441ffc43b3c0e8cc.jpg) ![](https://uploads.tapatalk-cdn.com/20190221/de6dbb2162258933b4c9a2ad552bd6e6.jpg)
Post by Mr Kipling on Feb 21, 2019 19:59:48 GMT 1
looking real good there Steve...cracking job...
Post by midlifecrisisrd on Feb 25, 2019 12:57:02 GMT 1
Got the rad grill fitted, just waiting on longer screws to replace the slightly short ones Also made up the headlight with a modern halo unit. Temporarily fitted the tank to set the lock stops Really need to get it fired up now😁 Steve ![](https://uploads.tapatalk-cdn.com/20190225/c7bcec6dcb6f197a9515f04ce578f5e3.jpg) ![](https://uploads.tapatalk-cdn.com/20190225/ee46a0a963964f8ed8bc3a73352c86a4.jpg)
Post by midlifecrisisrd on Feb 27, 2019 13:03:37 GMT 1
The correct length bolts arrived for the rad guard so drilled out the spacers (standard rad m5, Chinese m6) and fitted it permanently. Trimmed a couple of mm off the steering lock tab so now has a functional steering lock (not that I'd leave it parked with just that) Double checked the oil pump setting then fitted the carbon oil pump cover Steve ![](https://uploads.tapatalk-cdn.com/20190227/eed8dc815a19b63578ced59d9da27027.jpg) ![](https://uploads.tapatalk-cdn.com/20190227/54249c030f3cfc99bd180d0a6fe7359a.jpg)
Post by midlifecrisisrd on Mar 5, 2019 16:39:33 GMT 1
Made a mounting plate and bracket for the Ignitech. Also had to take the rear wheel off again as the fecking new tyre and newly coated rim aren't getting on Losing 1psi a day 🤬 Refitted and another new valve just in case Decided while the wheel and caliper bracket was off I'd drill the caliper bracket and spacers and for a couple of roll pins to hold it all together which makes wheel removal and befitting a lot easier Steve ![](https://uploads.tapatalk-cdn.com/20190305/a3bafa6000d420f25f15b656104df1a7.jpg) ![](https://uploads.tapatalk-cdn.com/20190305/bb9fb22f25262e62a781924ef3288f0c.jpg)
Post by dusty350 on Mar 6, 2019 21:39:50 GMT 1
Looking great Steve - I love the blue bodywork ![;)](//storage.proboards.com/forum/images/smiley/wink.png) And a neat idea with the roll pins. Makes life easier ! Dusty ![:)](//storage.proboards.com/forum/images/smiley/smiley.png)
Post by philmill on Mar 6, 2019 22:14:35 GMT 1
Looks great, I too really like the blue. Did you fit the headlamp into a std shell? could you tell me what size the light is? I'm looking for something for mine but away at work at the moment.
Cheers, Phil
Post by midlifecrisisrd on Mar 6, 2019 22:31:59 GMT 1
Looks great, I too really like the blue. Did you fit the headlamp into a std shell? could you tell me what size the light is? I'm looking for something for mine but away at work at the moment. Cheers, Phil Cheers Phil It's a carbon bowl but identical to LC The angel eye is fitted in standard rims One of the mini (car) ones Steve
Post by Yogi on Mar 8, 2019 19:18:26 GMT 1
Come on Steve get that imposter out your cave your hybrids skulking in the corner It’s come a long way since I last had a read,it looks like one of Dustys builds ![:D](//storage.proboards.com/forum/images/smiley/grin.png) Come back from the dark side before it’s too late Matt
Post by midlifecrisisrd on Mar 8, 2019 19:49:01 GMT 1
Come on Steve get that imposter out your cave your hybrids skulking in the corner It’s come a long way since I last had a read,it looks like one of Dustys builds ![:D](//storage.proboards.com/forum/images/smiley/grin.png) Come back from the dark side before it’s too late Matt It's ready to move out, just waiting for a dry day now 🙄 Moving it round to the garage before fitting the tank then road test then hopefully call the owner to collect it. First thing to do after the lc is gone is replace the fuel lines on the 385, charge the battery, oil change and fire it up. That will keep me busy while the 3hm1 forks are getting rechromed😁 That and the other 2 31k hybrids 😉 Steve
