Post by andysh2 on Sept 1, 2018 19:06:52 GMT 1
Hi All, Nearly completed my RD rebuild and I cannot get the Oil and Neutral lights to work, I have brand new bulbs fitted new wiring loom and a new neutral switch any ideas? I've not had the bike running yet just plugged a battery charger in to test everything.
Thanks,
Andy
Post by guiri on Sept 2, 2018 12:40:16 GMT 1
sounds silly.. but you sure it was in neutral..lol. take off the cable to the neutral switch..put it to ground..then see what happens.
Post by andysh2 on Sept 11, 2018 20:03:30 GMT 1
Yeah it's in neutral lol, I've put the cable to ground and it's made no difference so I've now had to take the fairing off and the headlamp out. I hate bloomin wiring problems. Going to double check everything again now.
robw
Post by robw on Sept 14, 2018 8:04:10 GMT 1
Check the connections to the oil level senser. I had a similar problem and found out it was that Rob
Post by andysh2 on Sept 16, 2018 20:26:03 GMT 1
I've tried another oil sensor, putting the neutral wire straight to earth, had the clocks back off checked all the bulbs and connections all fine, fitted another stator assembly and yet still no oil or neutral night?? I've no idea now there is no voltage on the light blue wire at the clock end? Oh and it's a brand new loom, neutral switch and ignition. Not sure it makes a difference as it didn't on my MK1 but I'm using a battery charger to check it all.
