trog
Post by trog on Aug 31, 2018 15:47:42 GMT 1
Just got a rd all numbers match except the last three, frame ends 710 engine ends 699 is it common for them to be that close together but not completely match, a do think the bike was imported at some time but not sure where from.........thanks for any help 👍
Post by stusco on Aug 31, 2018 19:21:48 GMT 1
It’s not matching they should be the same
Post by marrcel on Aug 31, 2018 19:51:13 GMT 1
Mmm here frame 002016 Engine 002008 its so close. Any other explaination in production proces?
Post by midlifecrisisrd on Aug 31, 2018 20:37:26 GMT 1
Just means the replacement engine came from a bike very close
I've had a couple of "close" matching bikes
As in 2 separate matching number bikes but a few hundred out
trog
Post by trog on Aug 31, 2018 21:41:10 GMT 1
Ok thanks..... doesn't matter to me, how much difference in value does it make
Post by museumman on Sept 10, 2018 11:59:26 GMT 1
I think Yamaha stamped the engines whilst in the bike to match frame. You sometimes see wonkey engine numbers. They should be matching.
I've had a Honda that was original un-touched that had an engine that was 1 or 2 numbers out. Possibly stamped on a diffeent line.
Post by petenofear on Oct 12, 2018 20:29:14 GMT 1
Very interesting topic
I have a Rd125lc mk2 frame sat in garage and I have a ypvh engine not from this frame
But number on frame And engine number the same but 1 number out
Both gm 00 But was unsure if the ypvh engine should have been in the gm and in the mk2 Frame
Post by bertiemollie on Oct 12, 2018 21:37:41 GMT 1
Very interesting topic I have a Rd125lc mk2 frame sat in garage and I have a ypvh engine not from this frame But number on frame And engine number the same but 1 number out Both gm 00 But was unsure if the ypvh engine should have been in the gm and in the mk2 Frame Mk2 UK RD125LC numbers start 1GM. 1GM is a non power valve model.
Post by petenofear on Oct 13, 2018 8:51:21 GMT 1
Just been looking I must have a m2 bottom engine with ypvh head on it then I get some photos up
Post by petenofear on Oct 13, 2018 8:57:35 GMT 1
