Post by Yogi on Aug 15, 2019 19:11:49 GMT 1
Cheers Shaun and Mr Veg 👍
Hopefully get some more pics soon
Matt 🐻
Post by Yogi on Aug 17, 2019 17:04:25 GMT 1
Quick update 🤣 Fitted rear panel with rechromed grab rail,replated brackets,new trim and rubbers Wheels sprayed with new bearings etc Still need to finish front discs and forks but it’s beer o’clock 🤣👍 Matt🐻🍺
Post by Yogi on Aug 18, 2019 17:48:01 GMT 1
Well after a ball ache of a weekend doing wheels and shocks I’m finally there Scotched the legs on the bench grinder then laquered now just need the bottom decal,lost it somewhere 😡 Found the inner ones typically Matt 🐻
Post by mouse on Aug 19, 2019 7:07:41 GMT 1
Looks superb Yogi, but given the choice i would prefer the hybrid you are building, but both are outstanding.
Mouse
Post by Yogi on Aug 19, 2019 10:20:41 GMT 1
Looks superb Yogi, but given the choice i would prefer the hybrid you are building, but both are outstanding. Mouse Lol,I know what your saying mate,I prefer the hybrid too but needed a change This is a restoration so has to be how our little friends built it originally ☺️☺️😂😂 I’ll get back to the hybrid soon 👍 Cheers Matt 🐻
Post by veg on Aug 20, 2019 8:50:34 GMT 1
Superb Matt
Post by Yogi on Aug 23, 2019 17:53:56 GMT 1
Switchgear done and dusted Just waiting for the barrels and crank to return from Grampians then engine build time Matt 🐻
Post by shaunthe2nd on Aug 23, 2019 19:30:40 GMT 1
I like those sort of jobs, switch gear and carbs are my favourites, find them very rewarding. Worst job is probably the wheels, but satisfying once done.
Keep up the good work and the pics flowing.
Post by Yogi on Aug 24, 2019 17:11:35 GMT 1
I like those sort of jobs, switch gear and carbs are my favourites, find them very rewarding. Worst job is probably the wheels, but satisfying once done. Keep up the good work and the pics flowing. Hi Shaun Trouble with being a fridge man in summer is getting time to do anything else 🥴 Been on 7 long days straight and only getting quick visits to the cave but I’m trying Cheers Matt 🐻👍🤣
Post by Dixie Dean on Aug 24, 2019 20:18:17 GMT 1
Hi rebuild looking good,I am doing a lc2 myself thy other white colour scheme,how easy are the switch gear to strip?
Post by Shytalk on Aug 24, 2019 20:28:36 GMT 1
Hi rebuild looking good,I am doing a lc2 myself thy other white colour scheme,how easy are the switch gear to strip? Simple, if you’re not sure take some pictures of them as you strip them, there’s only a few screws holding parts inside.
Post by Yogi on Aug 24, 2019 21:02:04 GMT 1
Hi rebuild looking good,I am doing a lc2 myself thy other white colour scheme,how easy are the switch gear to strip? Hi mate As shy said there quite easy,take a pic before taking out the screws on the insides The left ones the hardest,if you get stuck I’ve got pics of mine Cheers Matt 🐻
Post by dusty350 on Aug 24, 2019 21:39:31 GMT 1
Looking minty mint Matt Great work , as usual Dusty
Post by rfloyd350 on Aug 24, 2019 22:05:19 GMT 1
looking forward to seeing this finished. passed my test back in 84 and bought one of these brand new, keep up the very good work cheers.
Post by Yogi on Sept 7, 2019 19:26:36 GMT 1
Update time I’ve got all my engine parts back now For those that think over a grand for a decent engine is expensive 🥴 Here’s what approx £1500 worth of bits looks like Buttttt at least I can get back on it now Matt 🐻👌
Post by dusty350 on Sept 7, 2019 19:57:30 GMT 1
Costs of engine builds seems to increase every year I did 2 Lc engine builds, roughly a year apart, and the second definitely cost more than the first, for virtually the same job. I listed the prices of the parts bought on the second build so I could look back in a year or 2 and compare how much they have gone up by. Worst ever was Yamaha putting the price of a base gasket for a Pv up overnight from a fiver to £30 odd !! Couldn't believe it. I bought from Granby's at the time and they couldn't believe it either. Still, it's important to do it right, and that means the best possible parts, and that makes it spendy ! Enjoy the rebuild Matt Dusty
Post by Yogi on Sept 7, 2019 20:41:27 GMT 1
Costs of engine builds seems to increase every year I did 2 Lc engine builds, roughly a year apart, and the second definitely cost more than the first, for virtually the same job. I listed the prices of the parts bought on the second build so I could look back in a year or 2 and compare how much they have gone up by. Worst ever was Yamaha putting the price of a base gasket for a Pv up overnight from a fiver to £30 odd !! Couldn't believe it. I bought from Granby's at the time and they couldn't believe it either. Still, it's important to do it right, and that means the best possible parts, and that makes it spendy ! Enjoy the rebuild Matt Dusty Cheers Dusty Grampians relieved me of £545 for a rebore and crank rebuild 🤔 add £180 for the barrels and it’s adding up quick and for the 3rd time they’ve rebored standard barrels to +75 I’m well pissed off 😡 again Matt 🐻
Post by mouse on Sept 8, 2019 9:12:17 GMT 1
Beautiful job Yogi, did/do you lacquer the switch gear once you have put the decals on?
Cheers, Mouse
Post by Yogi on Sept 9, 2019 9:48:12 GMT 1
Beautiful job Yogi, did/do you lacquer the switch gear once you have put the decals on? Cheers, Mouse Hi Mouse I don’t normally lacquer them now due to a couple of mishaps with it reacting 🤬 Cheers Matt 🐻
Post by veg on Sept 14, 2019 9:09:44 GMT 1
Matt this is looking brilliant, I know you prefer your tarts handbag 😁, but got to say this is gorgeous. Re rebore to plus .75 did you tell them and they ignored you? Or did they attempt to justify by quoting barrel damage? Interested as to why they have done it 3 times.
Post by midlifecrisisrd on Sept 14, 2019 10:40:39 GMT 1
Matt this is looking brilliant, I know you prefer your tarts handbag 😁, but got to say this is gorgeous. Re rebore to plus .75 did you tell them and they ignored you? Or did they attempt to justify by quoting barrel damage? Interested as to why they have done it 3 times. I had the same the last set I sent. One standard with a little bit of visible wear, one 0.25 and looked good To be honest if they were matching I'd have ran them Came back on 0.75. They said the bore was oval so needed to go so big to clear it out Steve
Post by Yogi on Sept 14, 2019 10:46:27 GMT 1
Matt this is looking brilliant, I know you prefer your tarts handbag 😁, but got to say this is gorgeous. Re rebore to plus .75 did you tell them and they ignored you? Or did they attempt to justify by quoting barrel damage? Interested as to why they have done it 3 times. I had the same the last set I sent. One standard with a little bit of visible wear, one 0.25 and looked good To be honest if they were matching I'd have ran them Came back on 0.75. They said the bore was oval so needed to go so big to clear it out Steve Thanks veg👍 Lol,exactly what they said to me Steve and as I can’t prove otherwise 😡 The pistons are not specific to barrel either 🤔 Cheers Matt 🐻
Post by midlifecrisisrd on Sept 14, 2019 10:49:06 GMT 1
That's unusual
I sent 4 barrels (2nd set on 1.00 and 1.25. Bored to 1.75 so I just sold them to get my money back)
One pair marked A L+R, other B L+R
Post by Yogi on Sept 14, 2019 11:04:27 GMT 1
That's unusual I sent 4 barrels (2nd set on 1.00 and 1.25. Bored to 1.75 so I just sold them to get my money back) One pair marked A L+R, other B L+R Steve They do normally come back like that for me too but I can’t find any on these 🤔 Matt 🧸
Post by jon on Sept 14, 2019 11:13:34 GMT 1
I had the same the last set I sent. One standard with a little bit of visible wear, one 0.25 and looked good To be honest if they were matching I'd have ran them Came back on 0.75. They said the bore was oval so needed to go so big to clear it out Steve Thanks veg👍 Lol,exactly what they said to me Steve and as I can’t prove otherwise 😡 The pistons are not specific to barrel either 🤔 Cheers Matt 🐻 I used to get my rebores and cranks done by Bob Farnham (shame he retired ). Being just down the road (maybe 20 minutes) I was able to see worn parts as he did them. I remember one set of barrels I took for a rebore, he honed first and showed me where the marks were. It was noticeably oval at the inlet side where there is less support for the piston. Ended up going up 2 sizes to get the perfect bore. He too never used to name the pistons. BUT he did measure them first to check they were bang on size. I suspect if they weren’t he’d have numbered them. I weighed them too and they were spot on equal. Jon
Post by Yogi on Oct 5, 2019 10:34:42 GMT 1
Post by headcoats on Oct 5, 2019 12:09:58 GMT 1
P J Engineering will go up on sizes too but as you say the inlet side wears oval and needs boring out a lot more to sort it
I had barrels at 1.00mm over taken to 1.75 which was a shock
It had a tune too where the inlet windows are really opened up , so even less metal for support
Something to think about keeping them standard or just a clean up ?
Post by Yogi on Oct 22, 2019 16:43:42 GMT 1
Got home a bit earlier today so thought I’d get on with the engine rebuild at last Fitted the modded drum,selectors and both gear clusters with all new bearings Matt 🧸
Post by Yogi on Oct 27, 2019 20:01:41 GMT 1
Got a bit of time on this today so started building the top end All new valves,bushes,seals,valve caps,screws and everything else including new head bolts🥴 Then the realisation that I had used the new basket on the N1 build and couldn’t find the water union So I put the engine in to free up some bench space Matt 🧸👍
Post by veg on Oct 29, 2019 17:57:54 GMT 1
Is it me, but that seat doesn't appear to be right?
