Post by lc80crazydude on Jul 8, 2018 18:35:01 GMT 1
Hi all Basically im putting together an lc80 which is starting to look well. Ive got a *30w engine which has had a vapour blast/new crank etc but with it being 12v ..the existing battery compartment is designed for the 6v battery.Is theyre a 12v battery anyone knows of which will fit this battery box? also is anyone running a *30W in a mk1 frame.I have a 30W wiring loom etc and everything has been fine and dandy to fit.
Post by markhoopy on Jul 8, 2018 20:37:00 GMT 1
Have you looked at the gel-type batteries? They tend to be smaller than lead-acid ones, or you could look at Li-ion but they are more expensive than gel.
Post by lc80crazydude on Jul 26, 2018 23:10:23 GMT 1
Have you looked at the gel-type batteries? They tend to be smaller than lead-acid ones, or you could look at Li-ion but they are more expensive than gel. Got one on the way
