Post by jollyr6 on Jun 18, 2018 9:07:43 GMT 1
im running a micron 220 main jet question is in 5th/6th power seems to drop off really quick if i dont put it into band and have to keep cogging her back down any suggestions what it could be
Post by earthman on Jun 18, 2018 9:32:05 GMT 1
Maybe stating which bike you have would help with replies.
Why do you suspect that fuel is the problem for a start, has it been sat in the tank for longer than say 3 months?
Post by jollyr6 on Jun 18, 2018 12:24:35 GMT 1
its a 125lc mk 1 running a 12a carb jetted to 220 for micron not done a plug chop yet as just finished running it in it runs ok 1st 2nd and 3rd giving it the beans and goes right up to 10k revs but then when in band 5th and 6th seems to die off until you change down again
Post by mattybeckett on Jun 28, 2018 0:11:12 GMT 1
its a 125lc mk 1 running a 12a carb jetted to 220 for micron not done a plug chop yet as just finished running it in it runs ok 1st 2nd and 3rd giving it the beans and goes right up to 10k revs but then when in band 5th and 6th seems to die off until you change down again Has the gearing been highered. Eg bigger front sproket/smaller rear.
Post by jollyr6 on Jun 28, 2018 12:38:04 GMT 1
its a 125lc mk 1 running a 12a carb jetted to 220 for micron not done a plug chop yet as just finished running it in it runs ok 1st 2nd and 3rd giving it the beans and goes right up to 10k revs but then when in band 5th and 6th seems to die off until you change down again Has the gearing been highered. Eg bigger front sproket/smaller rear. i belive i put standard sizes on will need to check
Post by looey on Jun 29, 2018 17:14:04 GMT 1
Sounds like it's running like every 125LC I've ever ridden with a pipe on. Problem is......, the power delivery is so peaky, there's bugger all under 6-6.5k, so when the speed and resulting extra wind-resistance get's up, they won't even hold their speed out of the power band in 5th or 6th, let alone accelerate lol. It's either that or get a YPVS model, or a 250/350LC
