Post by dazzacfc on May 20, 2018 12:04:04 GMT 1
Hi all
Does anyone know which model of AP Lockheed Calipers will install onto a standard RD 350LC (I have the conversion brackets) just want to know if there is a specific Caliper Model.
Thanks
Dazzacfc
Post by steeley on May 20, 2018 19:06:38 GMT 1
Hi, I think the part number you need is cp2696.Use dot 4 fluid . Don't use any other stuff it will bugger the seals . How do I know . Been there done it .
Post by copper99 on Sept 29, 2019 11:13:40 GMT 1
Considering a set of these for my 4L0, are they are a worthwhile upgrade and work with the std master cylinder?
Any feedback appreciated .
Post by oldelsieboy on Sept 29, 2019 14:05:11 GMT 1
Post by rigga on Sept 29, 2019 15:25:21 GMT 1
Are these any better performance wise over blue spots though?
Post by copper99 on Sept 29, 2019 17:14:00 GMT 1
Lovely, thanks Nigel...anyone running these or the APs who can comment on performance esp with the OE master cylinder. I know Blue Spots would be a definite upgrade but not interested in those, just feedback on the APs.
Post by oldelsieboy on Sept 29, 2019 17:29:18 GMT 1
Lovely, thanks Nigel...anyone running these or the APs who can comment on performance esp with the OE master cylinder. I know Blue Spots would be a definite upgrade but not interested in those, just feedback on the APs. Just fitted a pair of AP's but with 320 discs, cant try them yet as I have to rebuild the motor first. OEB
Post by midlifecrisisrd on Sept 29, 2019 18:59:46 GMT 1
They are lovely Nigel. Did you get the speedo drive spacing sorted
Considering using a pair of these on the tr750
Post by oldelsieboy on Sept 29, 2019 19:07:48 GMT 1
They are lovely Nigel. Did you get the speedo drive spacing sorted Steve I'm working on it OEB
Post by steeley on Sept 29, 2019 19:33:25 GMT 1
Hi , I have had these on my lc for years and rate them I use an rgv250 m/cylinder because I also use rgv switch gear . I ran a pair of tzr carbs for years and wanted a handle bar choke . I found depending what make of pad you used you could after a while end up with slow speed squeal from them .
Post by copper99 on Sept 29, 2019 19:46:09 GMT 1
Hi , I have had these on my lc for years and rate them I use an rgv250 m/cylinder because I also use rgv switch gear . I ran a pair of tzr carbs for years and wanted a handle bar choke . I found depending what make of pad you used you could after a while end up with slow speed squeal from them . Thats bud, is an adaptor bracket required to fit them to the std fork legs? Will new brake lines be required as well? TIA
Post by beardy on Sept 30, 2019 8:17:23 GMT 1
I fitted these back in the 80’s so not made from today’s modern materials. I used to use the standard 350 master cylinder but found I didn’t have much feel and they felt very wooden. I now use a 250 master cylinder and it’s much better. I still have the splitter so only needed the lower brake lines. Although it now has all braided lines. They’re also quite capable of locking the font wheel up.
Post by steeley on Sept 30, 2019 8:41:00 GMT 1
Hi , I have had these on my lc for years and rate them I use an rgv250 m/cylinder because I also use rgv switch gear . I ran a pair of tzr carbs for years and wanted a handle bar choke . I found depending what make of pad you used you could after a while end up with slow speed squeal from them . Thats bud, is an adaptor bracket required to fit them to the std fork legs? Will new brake lines be required as well? TIA Hi , i had made a pair of braided lines for the bike years before fitting these and just hooked them up to the calipers . The banjo is different thread wise.Nigel at NK Engineering made the adapter plates.Oh the brake lines were made to length of the std hoses.
