Post by Tobyjugs on Jun 25, 2018 20:05:42 GMT 1
Even if the nut were loose, it may stay on the splines? A 3mm offset front sprocket does not sound enough for a 160, I’d expect 9mm. With the chain off clamp a straight edge to the front and rear of the sprocket and see if it aligns with the front sprocket. Jon Thanks for the comments but trust me we’ve done everything to the book. Have you seen our riddler build? Interesting conversation, I have a project with enough offset for a 180 possibly 190 width tyre and i have around 30mm offset +-5mm. i will measure it when i get the chance if it helps anyone.
Post by jon on Jun 25, 2018 20:20:59 GMT 1
I can’t understand there would be enough variation in the dimensions of the standard frame (around 201mm from measurements) to make this possible?
Sure you can angle the chain to clear the frame and tyre, as the tyre is not at exactly the same distance as the swingarm pivot.
I will draw a CAD drawing tomorrow to show what I mean.
Post by rsvr1000 on Jun 25, 2018 20:21:44 GMT 1
Nice would love the wheels you can afford those wheels KEN, just flog a bit more tarmac
Post by bazzer5115 on Jun 25, 2018 20:50:31 GMT 1
Mine are ypvs hybrids,I have always run 160/60x17 rears&120/70x17 fronts. I run d.i.d X-ring chains. Can’t remember what off-set front sprocket I have on them. I have the same clearances frame side as tyre side. No sign of chain touching at all. I built a LC hybrid a few years ago and ran that with a 160/60x17 rear,ypvs engine and again no problem,close but ok. Sold it to a forum member(rwebster)I think. You can get a narrow 520 x-ring chain. DID 520 VT2 x-ring,they narrower than std. Also not all 160/60 tyres are the same overall width. I run Michelin pilot power 2ct.
Post by russpuss on Jul 5, 2018 21:45:27 GMT 1
Post by loctite on Nov 3, 2018 7:57:59 GMT 1
Any updates russ
Post by russpuss on Nov 3, 2018 8:14:24 GMT 1
Got some yoshi rear sets for it it’s off the bench at the moment as I’ve undertaken a couple of other projects, but Mutts is building me the engine as soon as I can get the cases to him. Hopefully get stuck back into it soon.
Post by rostrumorhospital on Nov 5, 2018 8:28:42 GMT 1
Had nearly forgot about this one - really lookin forward to progress starting again good luck
Post by russpuss on Dec 16, 2018 21:52:59 GMT 1
So cases have gone to Dave, time to get stuck back in! Not sure whether to make adaptors for the existing mounts or cut the mounts off and just weld new 1’s up.
Post by botty on Dec 17, 2018 0:44:53 GMT 1
So cases have gone to Dave, time to get stuck back in! Not sure whether to make adaptors for the existing mounts or cut the mounts off and just weld new 1’s up. Wood Ken
Post by russpuss on Jan 22, 2019 20:35:46 GMT 1
Post by russpuss on Jan 22, 2019 21:14:32 GMT 1
Post by russpuss on Jan 22, 2019 21:32:23 GMT 1
that’s the gearing sorted
Post by russpuss on Jan 23, 2019 18:09:09 GMT 1
so today I’ve turned the spacers up for the rearsets, tea then off to Bri’s to get the frame all welded up properly and all the lugs not required chopped off, more pics later.
Post by russpuss on Jan 23, 2019 19:53:16 GMT 1
Post by russpuss on Jan 24, 2019 16:47:14 GMT 1
Post by muttsnuts on Jan 24, 2019 18:35:52 GMT 1
looking good russ, bit of delay on the engine, still no casings back as the vapour blaster has broken down or summat, hopefully get them back next week, then full steam ahead with the engine build.......
Post by russpuss on Jan 24, 2019 22:09:44 GMT 1
Post by bazzer5115 on Jan 24, 2019 22:54:19 GMT 1
Nice,about time somebody did something different on a LC hybrid. Thinking outside the box.👍
Post by muttsnuts on Jan 25, 2019 10:46:11 GMT 1
Nice,about time somebody did something different on a LC hybrid. Thinking outside the box.👍 you haven't seen the engine yet !!!!
Post by icarus001 on Jan 25, 2019 11:07:20 GMT 1
That looks ace, the idea of it sounded good and those latest pictures are even better.
Post by russpuss on Feb 26, 2019 9:21:04 GMT 1
today’s the day it gets its heart fitted.
Post by russpuss on Feb 26, 2019 14:18:21 GMT 1
Leave Dave to throw it together then off for the custom exhausts
Post by russpuss on Mar 27, 2019 18:19:43 GMT 1
Post by oldbritguy on Mar 27, 2019 18:34:55 GMT 1
Coming on great. From what is going on here you definitely "don't do normal"
Brilliant bit of fabrication and will result in an absolute stunner.
Maybe one of those "special" massages will help your back and get you back on the build pronto. Hope for a quick recovery bud
John
Post by midlifecrisisrd on Mar 27, 2019 18:46:12 GMT 1
Post by Mr Kipling on Mar 27, 2019 18:54:07 GMT 1
lovely looking engine nice driveline cylinders...Exhausts look great...
Post by russpuss on Mar 27, 2019 18:57:26 GMT 1
lovely looking engine nice driveline cylinders...Exhausts look great... Is that what they are? Just left it up to Dave
Post by dusty350 on Mar 27, 2019 19:36:57 GMT 1
Wow, those pipes look fantastic This is gonna be a stunning special. Sorry to hear about your back. Find yourself a good Osteopath - sooner rather than later. Don't rely on the NHS pain clinics, which is where I ended up. A few sessions with an Osteo will see you back on your feet far sooner. Good luck. Dusty
Post by botty on Mar 27, 2019 20:50:40 GMT 1
Looking good Ken.
Love the route of the pipes through the swingarm 👌👌😎😎
