Post by fozzy17 on Feb 12, 2019 20:47:06 GMT 1
I think colour scheme I am think gloss black with gold graphics like the old jodt like the John player special anybody know anyone who can do the graphics
Post by fozzy17 on Feb 21, 2019 15:38:14 GMT 1
Post by fozzy17 on Feb 25, 2019 18:31:21 GMT 1
Post by philmill on Feb 25, 2019 19:45:07 GMT 1
Is it just me, I can't see the pics and when I click on the box it doesn't show either...
Phil
Post by fozzy17 on Feb 25, 2019 19:47:02 GMT 1
I can see them? Anybody else see them?
Post by dusty350 on Feb 25, 2019 19:47:11 GMT 1
Right click on the box and select "open link". That is the only way I can see them - links you to Fozzy's pictures account. Dusty
Post by philmill on Feb 25, 2019 19:55:11 GMT 1
Yes, that way i can see them, but all his earlier pics open straight up..
What that rad like Fozzy, happy with it??
Phil
Post by philmill on Feb 25, 2019 19:56:31 GMT 1
I lied..... no they don't, but some have the dropbox link address and others just a question mark in the box.
Phil
Post by marrcel on Feb 25, 2019 21:23:37 GMT 1
I like the shape of the first part say first 10”. Then i miss some volume in the middle. Some german belly? OK that is just visual. May be there is a design reason? 🤔
Post by fozzy17 on Feb 25, 2019 22:10:30 GMT 1
Yes, that way i can see them, but all his earlier pics open straight up.. What that rad like Fozzy, happy with it?? Phil seem to be good, but not tested it under pressure waiting for a bracket before i fit 30% more capacity apparently but look almost stock cheap enough
Post by fozzy17 on Feb 25, 2019 22:11:28 GMT 1
I lied..... no they don't, but some have the dropbox link address and others just a question mark in the box. Phil try different browser i had that before, i can see them
Post by fozzy17 on Feb 25, 2019 22:12:57 GMT 1
Post by midlifecrisisrd on Feb 25, 2019 22:18:17 GMT 1
I can see all the previous pics but just links on the last
Post by LC_BOTT on Feb 25, 2019 22:20:22 GMT 1
All page 2 pics working fine for me Fozzy, also looking good so far
Post by jumpstart on Feb 26, 2019 7:58:59 GMT 1
fozzy interested to know what make are those front wavey disc, they look the biz mate nice build must say
Post by fozzy17 on Feb 26, 2019 9:04:33 GMT 1
they are from ebay, i suspect chinese but after reading a few reviews i pulled the pin and bought them, i think around £200 for front and rear..
Post by fozzy17 on Feb 26, 2019 15:38:18 GMT 1
Post by philmill on Feb 26, 2019 16:43:37 GMT 1
I like the look of those clutch covers, as you say, not cheap but if the quality is there then well worth it.
Phil
Post by fozzy17 on Mar 1, 2019 21:36:19 GMT 1
Pipes fitted
Post by fozzy17 on Mar 4, 2019 8:23:25 GMT 1
Post by fozzy17 on Mar 4, 2019 8:25:41 GMT 1
Post by midlifecrisisrd on Mar 4, 2019 9:15:33 GMT 1
I'm liking that rad
Bigger than standard but not 40mm thick
Where did you get it?
Post by fozzy17 on Mar 4, 2019 9:25:05 GMT 1
Post by fozzy17 on Mar 4, 2019 20:45:03 GMT 1
Ran it today second kick, on stock carbs atm.
Post by fozzy17 on Mar 4, 2019 20:47:29 GMT 1
The oil pump is stamped 4L1 in a ypvs is that correct?
Post by midlifecrisisrd on Mar 4, 2019 20:59:14 GMT 1
The oil pump is stamped 4L1 in a ypvs is that correct? Yes most have a 4l1 pulley on them As long as course drive and yellow paint dot Steve
Post by fozzy17 on Mar 4, 2019 22:13:08 GMT 1
I had a quick look in manual and it stated the oil pump is set different on the later model N1 is that right? Set in the closed position
Post by midlifecrisisrd on Mar 5, 2019 10:14:23 GMT 1
Yes I've read it somewhere there was a set up where it was done on closed throttle
I always set to the long mark on WOT
I'd rather it was oiling correctly at full chat than idle
Post by fozzy17 on Mar 6, 2019 16:37:07 GMT 1
Guy a few quick question, i am going to run my ypvs carbs for now just to get the bike running (i am awaiting norbo to get some reed spacers made for the 28mm pwk) anybody know the float height on theseand i am going for 290 main jets for a base setting that sound about right with i am running air box the other one is the pwk carbs have a believe balancer pipe connectors like whats on the rd both on the inside of each carb about 3/4 the way up, can i block these?
Post by midlifecrisisrd on Mar 6, 2019 18:11:59 GMT 1
Guy a few quick question, i am going to run my ypvs carbs for now just to get the bike running (i am awaiting norbo to get some reed spacers made for the 28mm pwk) anybody know the float height on theseand i am going for 290 main jets for a base setting that sound about right with i am running air box the other one is the pwk carbs have a believe balancer pipe connectors like whats on the rd both on the inside of each carb about 3/4 the way up, can i block these? If 31k carbs the 290 with airbox should be rich enough for a tuned motor with pipes The pwk stubs are breathers from the float bowls Little bit of breather tube like the rd carbs Steve
