Post by dave1963 on Mar 25, 2018 12:19:07 GMT 1
Hi has mutts tested the x block reeds yet i am interested in them Thanks dave
Post by jackjabba on Mar 25, 2018 16:34:28 GMT 1
I saw him on Thursday and he hasn't had any from Norbo or the UFO inserts.
Post by dave1963 on Mar 25, 2018 16:48:59 GMT 1
Ok thanks will have to wait a bit longer unless anyone has tried them Thanks dave
Post by ringding on Mar 25, 2018 17:58:34 GMT 1
From reading Graham Bell's book these won't add anything to peak power, if your bike is already jetted for peak power. The advantage is that they should remove the part throttle 'lean stumble' which some people compensate for by running a bit more rich. Consequently, if you've done that then they offer the opportunity to lean off a bit and gain more power.
As I understand it they should aid ride-ability through giving a smoother transition onto larger throttle openings. For road riding that's probably an advantage worth paying for.
Post by peter007 on Apr 13, 2019 17:37:36 GMT 1
Hi guys anyone got a update on these ufo inserts yet has anyone used them or had them on a dyno ? Cheers Pete
Post by Norbo on Apr 13, 2019 17:55:20 GMT 1
get a set and try them LOL see if you feel a good improvement .
Post by tacky1 on Apr 13, 2019 18:49:02 GMT 1
I run a set of these my one of my 500s with 34mm carbs. I ran the bike for a few thousand miles before fitting them. Swapped out the pilots and noticed a little better midrange. That’s it. Bike picked up better say when diddling along in traffic or just dinking along on a twistie. Don’t know if they are worth it though.
Post by 0h5h1t on Apr 13, 2019 18:54:31 GMT 1
get a set and try them LOL see if you feel a good improvement . Why don't you send me some and yea ill see if there is an improvement.
Post by Norbo on Apr 13, 2019 20:06:35 GMT 1
I allready know they do ive sold a few sets to other people
Post by peter007 on Apr 13, 2019 21:48:45 GMT 1
I allready know they do ive sold a few sets to other people I’m happy to be your guinea pig norbo I’ve rebuilt my motor and it runs really sweet as it is so send me a set for 26mm lc carbs if they work I’ll do a write up and pay for them if not I’ll return them ? 😀
Post by Norbo on Apr 13, 2019 22:02:07 GMT 1
I dont send things out for people to fit see if they like them and decide if they want to pay for them or return them LOL. reserchen like the other people that had them and then get back to me . check out Banshee forums in the US
Post by bare on Apr 14, 2019 0:03:05 GMT 1
Possibly impolitic :-) But? if you have or have a mate with a 3d printer? Cobble up a pair for yourself. It's a simple item to draw and print
Post by peter007 on Mar 15, 2020 11:32:18 GMT 1
i wonder if any of the specialists on the forum might understand this review and help people decide if they wanna try the UFO inserts ? mutts have you any take on these results ? 3cyl.com/mraxl/manuals/ufo/UFOreview.pdf
Post by muttsnuts on Mar 16, 2020 10:16:49 GMT 1
i wonder if any of the specialists on the forum might understand this review and help people decide if they wanna try the UFO inserts ? mutts have you any take on these results ? 3cyl.com/mraxl/manuals/ufo/UFOreview.pdfI've not tested any, but the theory is correct (in my opinion) that straightening the air flow will give increases in mid range, it will do nothing (I suspect) for peak power as at that point on WOT the slide is completely out of the air flow so won't be causing any distrubance as such to the air flow. The shape/design of them should help accelerate the air past the pilot and main jet, this will help atomistaion of the fuel and the better you do that, the more fuel you will burn and not throw down the exhaust, so for a given amount of fuel you should get more efficient burning. As I say, this is all theory on my part, but that is what I would say is how they work, but I've no data/real testing to back any of that up Hope it helps anyway
Post by Norbo on Mar 16, 2020 11:34:55 GMT 1
I have done a few sets of theys for people in both standard and bigger carbs and every one has got back to me and said they were ace but a bugger to get right a far bit of messing about with pilot jets going smaller not bigger
Post by muttsnuts on Mar 16, 2020 12:25:42 GMT 1
yes logic would suggest that smaller jets would be required on the pilot side as the draw would be greater on the fuel, so more being pulled, making it run rich in the mid range etc
Post by tacky1 on Mar 16, 2020 20:52:16 GMT 1
I run these on both my 500s, I have 34mm carbs on them, They did make a big difference in low down power, Gave it more pull in the lower revs, They were pretty gutless under 4k, The guy who supplied the carbs and cable kits suggested them and I tried them on one bike, Massive improvement, I can pull from idle in top gear, I would suggest running them on a bike with carbs that will take them, I dropped from a 35 pilot to a 15 pilot and it runs perfect...
Post by wallcraft on Mar 16, 2020 21:45:43 GMT 1
I made a enquiry about these for my 34mm mikuni's with motocarb up in Liverpool, he put me off as he said they work best on a race bike, he also needed the carbs to do some machining on the slides and and carb body!! So in the end stuck with me pwk28s which already do what the UFO inserts try and do regarding spray pattern etc...
Post by tacky1 on Mar 17, 2020 0:56:46 GMT 1
I didn’t have to machine anything to make the work on my mikuni 34s. I did have to sand a little off the actual ufo insert as it was holding the slide open a bit and making the bike idle higher. Easy fix.
Post by bare on Mar 17, 2020 19:07:42 GMT 1
I made a enquiry about these for my 34mm mikuni's with motocarb up in Liverpool, he put me off as he said they work best on a race bike, he also needed the carbs to do some machining on the slides and and carb body!! So in the end stuck with me pwk28s which already do what the UFO inserts try and do regarding spray pattern etc... What !? Wisdom.. here ? Who woulda thought... Good on you.
Post by peter007 on Mar 20, 2020 20:56:50 GMT 1
Well I think I’ll give these a go when and if this corona problem calms down I’ll get a few different sets of smaller pilot jets in readiness watch this space guys 👍🤞
Post by Norbo on Mar 20, 2020 21:41:25 GMT 1
well i have them in if you want a set
Post by peter007 on Mar 20, 2020 23:04:17 GMT 1
well i have them in if you want a set Do you have genuine pilots to norbo? What size would you go down to at first ?
Post by Norbo on Mar 20, 2020 23:32:22 GMT 1
yes i do depends what size are fitted to the carbs your using
Post by tacky1 on Mar 21, 2020 4:03:41 GMT 1
Well I think I’ll give these a go when and if this corona problem calms down I’ll get a few different sets of smaller pilot jets in readiness watch this space guys 👍🤞 I run 15s in mine and they are perfect. I did have 20s, then 17.5s and they too rich. Better to start big and work back.
Post by peter007 on Mar 21, 2020 8:53:02 GMT 1
Well I think I’ll give these a go when and if this corona problem calms down I’ll get a few different sets of smaller pilot jets in readiness watch this space guys 👍🤞 I run 15s in mine and they are perfect. I did have 20s, then 17.5s and they too rich. Better to start big and work back. Hi tackyits been that long since i stripped my carbs im not sure what i have in mine and can't find my notebook at the mo ( some has been tidying up !) but im fairly sure im on 22.5's so i think ill try 17.5's first then down to 15's . what did you notice to tell you too rich? black plugs or running lumpy and hesitant ? I've also raised my needles as in putting the clip into the fourth groove down from the top to get the best feel , i'll try the needle where it is at first i think would you agree after you've done a fair bit of fiddling with yours ? how much difference did you notice after you got yours dialled in ? and would you recommend guys using them ? cheers Pete
Post by tacky1 on Mar 21, 2020 18:36:49 GMT 1
Pete, Black and fouling plugs and stumbled a lot in the lower revs, Plugs are perfect now and pulls really well,
