Post by kman on Jan 20, 2018 2:05:56 GMT 1
Gday. Any of you 4l0 guys running tarozzi rearsets. Ive fitted mine and the sidestand fouls the gear lever. How are you guys getting round this. Cheers
Post by JonW on Jan 20, 2018 12:29:26 GMT 1
...and the kicker probably fouls the brake... unless you do the mod to spin the footrest backwards. Thats one reason Ive always stayed away from them :/
Post by kman on Jan 21, 2018 0:54:29 GMT 1
Brake pedal was an easy fix. Put the pedal in the lathe and cut a small amount of it.
Post by steeley on Jan 21, 2018 6:48:47 GMT 1
I put a chamfer on the brake peddle . Cant remember having trouble with the gear change side . I will have a look Monday morning and will take the camera with me.
Post by rich on Jan 21, 2018 11:31:03 GMT 1
Can you put a blob of weld on the sidestand fork so it doesn't sit up so far? I had to do the same with mine, although they are different rearsets to yours.
Post by stusco on Jan 21, 2018 11:58:11 GMT 1
I used 10mm spacers and the brake pedal flip up mod ,then went back to standard footrest,so I’ve got a set for sale if anyone wants them
