Post by philmill on Jan 18, 2018 9:54:45 GMT 1
Hi guys, whats the general idea for changing or modifying steering stops on RGV yokes? is it best to cut off old ones and weld new? I don't really want it to look like a bodge so all suggestions welcome. Thanks.
Post by headcoats on Jan 18, 2018 11:49:55 GMT 1
Some weld new stops on or cut off the old ones then drill and tap for an M8 allen bolt ?
Post by Mr Kipling on Jan 18, 2018 16:14:56 GMT 1
if u drill n tap it hide the bolt in a recessed alloy sleeve/spacer ... Nige at nk does a good job of welding on a nice set of lock stops...
Post by jon on Jan 18, 2018 19:38:05 GMT 1
I personally like the drilled and tapped option too.
As Mr Kipling says you can either make a nice alloy sleeve, or do as I do and turn a stainless threaded stop down. The advantage of this is you can have minor adjustment by making the stops or sleeves slightly different diameters to fine tune.
Post by philmill on Jan 18, 2018 20:02:58 GMT 1
Thanks, I like your thinking Jon, the problem with with Nigel is he cant take any more work until summer he told me. I guess I'll try and get something made up.
Post by jon on Jan 18, 2018 20:26:41 GMT 1
Drilling and tapping the holes is not beyond most peoples aptitude.
I could make either sleeves or stops to screw in.
