Post by andy71330 on Jan 17, 2018 23:48:33 GMT 1
Getting a shopping list for norbo, getting the combined digital ignition and cdi, bahsee coils, give it a decoke and a carb overhaul, any other things I should consider doing? My intention is to run the bike this year and do a rebuild similar to what mouse has done on his next winter, as you all know these things are expensive, looking to spread the cost by doing it this way and getting some much needed play time, would really appreciate your thoughts on this. Andy
Post by philmill on Jan 17, 2018 23:56:45 GMT 1
I like your thinking, I would love to have been able to ride mine for a bit, but being an import means MOT, so no way its being ridden for a while, a long while!
Post by andy71330 on Jan 17, 2018 23:59:50 GMT 1
Can't wait, bursting to get out, all going well, it's looking like the beginning of April
Post by mattybeckett on Jan 18, 2018 1:08:34 GMT 1
Getting a shopping list for norbo, getting the combined digital ignition and cdi, bahsee coils, give it a decoke and a carb overhaul, any other things I should consider doing? My intention is to run the bike this year and do a rebuild similar to what mouse has done on his next winter, as you all know these things are expensive, looking to spread the cost by doing it this way and getting some much needed play time, would really appreciate your thoughts on this. Andy Don't do everything at the same time as you will have no ideas if any problems arise what's done what!!! 1 step at a time .
Post by andy71330 on Jan 18, 2018 1:18:59 GMT 1
Getting a shopping list for norbo, getting the combined digital ignition and cdi, bahsee coils, give it a decoke and a carb overhaul, any other things I should consider doing? My intention is to run the bike this year and do a rebuild similar to what mouse has done on his next winter, as you all know these things are expensive, looking to spread the cost by doing it this way and getting some much needed play time, would really appreciate your thoughts on this. Andy Don't do everything at the same time as you will have no ideas if any problems arise what's done what!!! 1 step at a time . The engine ran fine, just looking at a couple of changes to improve performance and reliability
Post by bare on Jan 18, 2018 4:37:57 GMT 1
One answer: IMO there are Only 2 conditions for these engines.. A) just rebuilt B) in need of a rebuild Be a shame to 'run it for a while' and do serious /expensive damage.. because you had NO knowledge of how good OR bad it was. Even more foolish to "tune it" blindly. A less than prime condition engine will Suffer.. often badly. With heavier than usual perf loadings resulting from piecemeal "improvements" whilst in Semi Clapped condition Best to: Remove the cyls to check the rod play for insight into current crank condition. Gauge the bores and look at the pistons to see IF they will survive the "improvements"
Post by andy71330 on Jan 18, 2018 10:41:29 GMT 1
One answer: IMO there are Only 2 conditions for these engines.. A) just rebuilt B) in need of a rebuild Be a shame to 'run it for a while' and do serious /expensive damage.. because you had NO knowledge of how good OR bad it was. Even more foolish to "tune it" blindly. A less than prime condition engine will Suffer.. often badly. With heavier than usual perf loadings resulting from piecemeal "improvements" whilst in Semi Clapped condition Best to: Remove the cyls to check the rod play for insight into current crank condition. Gauge the bores and look at the pistons to see IF they will survive the "improvements" Sound advice,thanks, andy
Post by simon998 on Jan 18, 2018 11:28:30 GMT 1
Did Norbo ever mention that he'd sell the banshee coils separately? I fancy one for the 125.
Post by andy71330 on Jan 18, 2018 14:03:42 GMT 1
You'd need to speak to him
