Post by petehodges on Jan 15, 2018 11:28:26 GMT 1
Hi lads Started doing a bit of maintenance on the n1 yesterday when I see a tie wrap round holding the oil tank ? What’s the score? I take it there’s a bracket for that ? Anyone got one? Cheers Pete
Post by markhoopy on Jan 15, 2018 12:07:18 GMT 1
Not the best pic but this is mine:
Post by markhoopy on Jan 15, 2018 12:11:04 GMT 1
This pic is a bit worse but you can see the bracket on the frame where the oil tank bolts to ..
Post by petehodges on Jan 15, 2018 12:27:30 GMT 1
This pic is a bit worse but you can see the bracket on the frame where the oil tank bolts to .. Ahh thanks mark so mine has had the bracket cut off then ! I’ll have to try make something up Thanks for the pic mate 😊
Post by wwwRD350LCnet on Jan 15, 2018 18:07:05 GMT 1
Broken oil tank bracket, so cable tie as a quick fix. I had this bracket cracks on my 2 F2's and had done a small bracket bolted on the hole in the frame where the cable tie pass through...
Xavier
Post by Yogi on Jan 15, 2018 18:40:50 GMT 1
I've had a few broken there too Must be to flimsy with all the oil swishing about As said I've bolted a bracket through the frame as well Unless it's a resto of course
Post by JonW on Jan 15, 2018 22:39:31 GMT 1
They are flimsy and often get blasted off if having powdercoating done.
