Post by dono on Jan 13, 2018 20:14:05 GMT 1
Ooh, good luck with the miss,s and of course your engine.. Dono
Post by Tobyjugs on Mar 3, 2018 21:37:22 GMT 1
Is this a wet or dry clutch?
Post by Mr Kipling on Mar 3, 2018 22:10:39 GMT 1
Is this a wet or dry clutch? hi Tob,s its for the dry clutch motor outta me used to be Fighter..
Post by Mr Kipling on May 1, 2018 14:10:50 GMT 1
Post by bezzer on May 1, 2018 16:52:13 GMT 1
Looking forward to following this build Mr Kipling!, good luck with it mate ๐๐ป. Pardon my ignorance but what is the benefit of the single bronze clutch plate youโre using?. Apologies in advance if itโs a daft question, but itโs the first time Iโve heard them mentioned.
Post by Tobyjugs on May 1, 2018 18:19:07 GMT 1
Hello Mr K I hope you don't mind answering a few questions.
What kind of clutch basket is that?
How many plates does it take?
Ist it the same diameter as a Standard rd Basket?
Can we see the back of it?
Post by Mr Kipling on May 1, 2018 18:24:44 GMT 1
Looking forward to following this build Mr Kipling!, good luck with it mate ๐๐ป. Pardon my ignorance but what is the benefit of the single bronze clutch plate youโre using?. Apologies in advance if itโs a daft question, but itโs the first time Iโve heard them mentioned. Not a daft Q mate , its literally a bronze clutch plate normal TZ plates have a habit of breaking , u pop this one in first too help combat that ...
Post by Mr Kipling on May 1, 2018 18:33:58 GMT 1
Hello Mr K I hope you don't mind answering a few questions. What kind of clutch basket is that? How many plates does it take? Ist it the same diameter as a Standard rd Basket? Can we see the back of it? G,day mate , its a std TZ 350 Clutch basket I use 6 TZ plates , its the same outer diameter but that's it...
Post by Tobyjugs on May 1, 2018 18:56:12 GMT 1
Hello Mr K I hope you don't mind answering a few questions. What kind of clutch basket is that? How many plates does it take? Ist it the same diameter as a Standard rd Basket? Can we see the back of it? G,day mate , its a std TZ 350 Clutch basket I use 6 TZ plates , its the same outer diameter but that's it... Time to start an internet search. Thanks
Post by Mr Kipling on May 1, 2018 19:07:51 GMT 1
Had a bit of free time so re installed bearing n bush etc popped studs back in an slotted the selectors n drum back in.. I,ll round up a Nova equipped gearbox an the crankshaft then pop them in an get the cases sealed.. Pics to follow..
Post by dusty350 on May 1, 2018 19:58:08 GMT 1
Looking forward to the build mate And I'm glad you got on well at Cox 's - they are good guys and always do excellent work. I've been using them since the late 80's when I had my 400. I always rinse mine when I get them home - Cox's do rinse with hot water but I like to give them another go when I get home, and I have got a little bit of blast media out in the past, so worth doing Dusty
Post by Mr Kipling on May 1, 2018 22:11:26 GMT 1
Looking forward to the build mate ;) And I'm glad you got on well at Cox 's - they are good guys and always do excellent work. I've been using them since the late 80's when I had my 400. I always rinse mine when I get them home - Cox's do rinse with hot water but I like to give them another go when I get home, and I have got a little bit of blast media out in the past, so worth doing ;) Dusty :) Yeah , there good lads at Cox,s done 2 sets for me now 2 more to do... like yourself I pop bolts in the threads beforehand but still tap n rinse well for good measure , thxs again..
Post by Mr Kipling on May 2, 2018 14:37:22 GMT 1
So rounded up the crankshaft an Nova Equipped gearbox at set too , first up was too fit new Gen Yamaha crank seals I recently replaced the gearbox bearings with gen Yamaha items so these went back in , after sealing n torqueing up the cases I got something starting to resemble a motor.. Later I,ll pop the top end on an torque up the billet head.. New Seals going in
Crankshaft n gearbox playing nicely together..
Side view during assembly
Post by oldbritguy on May 2, 2018 15:53:07 GMT 1
Once again, Mr Kipling does build exceedingly nice machines. Your threads are a pleasure to watch. I just wish I had the skill and patience. John
Post by bezzer on May 2, 2018 15:55:48 GMT 1
Once again, Mr Kipling does build exceedingly nice machines. Your threads are a pleasure to watch. I just wish I had the skill and patience. John Bug*er!, you beat me to the famous quote mate! ๐คฃ
Post by Mr Kipling on May 2, 2018 16:35:52 GMT 1
Once again, Mr Kipling does build exceedingly nice machines. Your threads are a pleasure to watch. I just wish I had the skill and patience. John I,m exceedingly good at making cakes disappear too ... (rofl) :D ;)
Post by Mr Kipling on May 2, 2018 16:56:23 GMT 1
Post by Tobyjugs on May 2, 2018 17:42:31 GMT 1
I agree with the other lads about this thread, very interesting. I have some more questions๐ This is a TZ primary wheel for the clutch, has it been specially modified for the kick start? If you do not need a kick start would there be a large bush in the Kickstarter cogs position. This thread has made me reslise that trying to graft a Ducati clutch to my engine is just way too time consuming and i should just stop being a tight git and buy the necessary parts
Post by Mr Kipling on May 2, 2018 18:05:57 GMT 1
This is a TZ primary wheel for the clutch, has it been specially modified for the kick start? This thread has made me reslise that trying to graft a Ducati clutch to my engine is just way too time consuming and i should just stop being a tight git and buy the necessary parts Std TZ primary unmodified has gear already on the back of it.., used to run on a std TZ outer cover too begin with. ( I,ll refit this when I,m out on it at trackdays ) ... Hth...
Post by Tobyjugs on May 2, 2018 18:44:04 GMT 1
Last night i did a bit of checking on the internet and i think i will give TZ 350 NET a ring
Post by Mr Kipling on May 2, 2018 19:11:31 GMT 1
Post by Mr Kipling on May 2, 2018 20:09:35 GMT 1
Post by Tobyjugs on May 2, 2018 20:31:29 GMT 1
Is the pump flow adjustable? I have been doing cooling water tests and have been thinking about restricting the flow of a standard 4LO pump to see if i can get a better Delta T over the engine and see what happens to the temperature
Post by Mr Kipling on May 2, 2018 20:49:20 GMT 1
With an auxillary controller , yes , it,ll allow me to run the engine on for a few minutes after I switch off it,ll also control the temp times on electric fan too...
Post by Mr Kipling on May 3, 2018 8:46:19 GMT 1
Thought I,d finish this off this morning but hit a small Snag the inner bearing in the clutch mod doesn't fit my rd shaft , small minor detail just means buying a diff bearing..Next time u see this engine now will be tucked up in a chassis...
Post by Tobyjugs on May 3, 2018 13:33:28 GMT 1
That looks nice much better than a washing machine window ๐
Post by Mr Kipling on May 3, 2018 15:21:54 GMT 1
All tucked up in its chassis now , thxs for viewing ....
Post by 4l04ever on May 4, 2018 14:00:08 GMT 1
What is the purpose of the huuuuuge reed block spacers? Is it just to allow huuuuge carbs to fit?
Post by oldbritguy on May 4, 2018 14:33:04 GMT 1
I know that on 4 Strokes the distance between the carb main jet venturi and the inlet valve has an impact on performance particularly when tuning. I imaging that it is something similar with 2T and distance to ports for max fuelling/air mix. I am sure someone with greater knowledge will come up with a good explanation for the huuuuuge spacers on the reed blocks
Post by bezzer on May 4, 2018 14:44:17 GMT 1
Looks the bizzo Mr K!, Thanks for indulging us ๐๐ป๐๐ป๐๐ป
