Post by wangwang on Jan 7, 2018 22:43:41 GMT 1
Recommendations please preferably in the North West to do the bush mod on my LC crankcase for the gear selector shaft. Cheers Wang
Post by 4l04ever on Jan 7, 2018 23:28:50 GMT 1
Try Grampian
Post by dusty350 on Jan 8, 2018 8:55:47 GMT 1
Dave "Muttsnuts" can do it but not sure how far he is from you ? He is in Malton. Dusty
Post by muttsnuts on Jan 8, 2018 12:47:46 GMT 1
I am at YO17 9DS, I can do it while you wait snd also have the bushes on stock
Regards
Dave
Post by wangwang on Jan 8, 2018 13:21:25 GMT 1
I am at YO17 9DS, I can do it while you wait snd also have the bushes on stock Regards Dave Cheers PM sent
Post by wangwang on Jan 14, 2018 19:34:58 GMT 1
Sorted, thanks to Dave.
Post by mossquire on Feb 11, 2018 22:17:39 GMT 1
I am at YO17 9DS, I can do it while you wait snd also have the bushes on stock Regards Dave I hold the flag of 'There's no such thing as a stupid question'to ask what the mod is? I bought a longer bush from NORBO as I understand it is a weak point but not sure what the mod is and is it forgetting fitting the longer bush and going for this as I am not that far from York
Post by dusty350 on Feb 12, 2018 8:57:42 GMT 1
The mod requires the hole that the shaft passes through on the sprocket side to be reemed out so the steel bush can be pressed in. Lc cases don't have the bush as standard - Ypvs cases do, although the one Norbo sells is slightly longer and protrudes on the inside of the case, adding support to the gear shaft. It's done because 30+ years of a steel gear shaft moving in a bare alloy hole wears the alloy and leads to oil leaks that the seal struggles to contain. Lc's and Pv's aren't particularly leaky engines, but when they do leak, gear shaft and neutral switch are usually the culprits. For the gear shaft bush, you ideally want bare cases, so a good thing to do at the start of a bottom end rebuild Dave will sort you out !! Dusty
Post by muttsnuts on Feb 12, 2018 14:39:58 GMT 1
I am at YO17 9DS, I can do it while you wait snd also have the bushes on stock Regards Dave I hold the flag of 'There's no such thing as a stupid question'to ask what the mod is? I bought a longer bush from NORBO as I understand it is a weak point but not sure what the mod is and is it forgetting fitting the longer bush and going for this as I am not that far from York just PM me if you want this doing, takes on average an hour to sort it properly on LC cases, less on PV cases (most of it is setting up on the milling machine)
Post by wallcraft on Feb 12, 2018 23:34:24 GMT 1
Quick question, will the ypvs bush push out and push in with the new extended one without machining? Thanks Mark
Post by midlifecrisisrd on Feb 12, 2018 23:41:02 GMT 1
Quick question, will the ypvs bush push out and push in with the new extended one without machining? Thanks Mark Ypvs cases take either the extended Bush or the gen yam one with no mods Steve
Post by mossquire on Feb 15, 2018 12:38:07 GMT 1
So, God my heads a shed learning all the bits and pieces. Mine is a YPVS and so has the bush which I have bought the extended one. Do I still need the mod? as mine is stripped for a rebuild and I am not far away from York (Harrogate for next two weeks), if it will be beneficial I will have it done. Dave, do you do any weld/repair work? It had a broken clutch guide bolt which, when cleaned has a slight crack in the side of the flange.
Post by midlifecrisisrd on Feb 15, 2018 18:56:26 GMT 1
So, God my heads a shed learning all the bits and pieces. Mine is a YPVS and so has the bush which I have bought the extended one. Do I still need the mod? as mine is stripped for a rebuild and I am not far away from York (Harrogate for next two weeks), if it will be beneficial I will have it done. Dave, do you do any weld/repair work? It had a broken clutch guide bolt which, when cleaned has a slight crack in the side of the flange. No mod needed, the old one will drive out then gently tap the new one in Steve
