Post by guiri on Jan 6, 2018 19:15:50 GMT 1
ive bought some banshee barrels for my ypvs race bike and just wondered if anyone knows if the standard ypvs head works on them..
im sure dave..muttsnuts would know...where are you dave..lol.
Post by jessy03 on Jan 6, 2018 19:29:38 GMT 1
Banshee head didn’t my ypvs, guess not Jess
Mad Biker
We lead others try and follow.
Post by Mad Biker on Jan 6, 2018 19:45:20 GMT 1
unfortunatley they are not interchangeable
Post by guiri on Jan 6, 2018 20:55:11 GMT 1
ok cheers chaps.
Post by jon on Jan 7, 2018 10:43:45 GMT 1
You’ll have to weld a 90 degree elbow on your banshee head on the outlet. I don’t know if there is enough pipe protruding to cut it at 45 degrees and ‘lobster back’ it? If not I’m sure pipe the right diameter can be sourced. Fail that turning down a tube would allow you to make a lip on the end to retain the pipe better. Welding cast to billet is specialised though as I know there are separate rods for either cast or billet.
Post by 4l04ever on Jan 7, 2018 11:12:11 GMT 1
So is the difference the outlet pipe position/angle and the lack of thermostat housing?
Post by Tobyjugs on Jan 7, 2018 13:25:02 GMT 1
I have a banshee head which will be going into a track bike and if i have to change the outlet i was thinking of machining it off and bolt a block on with an O-ring. This would be similar to the wicked head design for the inlet of their cylinder heads.
Post by LC_BOTT on Jan 7, 2018 18:10:52 GMT 1
I have a banshee head which will be going into a track bike and if i have to change the outlet i was thinking of machining it off and bolt a block on with an O-ring. This would be similar to the wicked head design for the inlet of their cylinder heads. Similar to what I was thinking, or you could get a 180 degree hose but wasn't sure where it needs to end up. Maybe need an inline joiner required too.
Post by Tobyjugs on Jan 7, 2018 18:16:58 GMT 1
I have a banshee head which will be going into a track bike and if i have to change the outlet i was thinking of machining it off and bolt a block on with an O-ring. This would be similar to the wicked head design for the inlet of their cylinder heads. Similar to what I was thinking, or you could get a 180 degree hose but wasn't sure where it needs to end up. Maybe need an inline joiner required too. I think an angled block would take up less room. 180 degree bend
Post by markhoopy on Jan 7, 2018 18:48:07 GMT 1
you could get a 180 degree hose but wasn't sure where it needs to end up A 90 degree hose you mean? It would be a tight fit, as the actress said to the bishop.
Post by Norbo on Jan 13, 2018 11:40:59 GMT 1
unless they are after market barrels banch barrels have less BHP then standard 350 ypvs they are more like the lc at about 45 or less , and no ypvs heads thewater jacket do not fit but if you are still looking drop me a line i may be able to help with a head
