Post by stusco on Jan 4, 2018 20:07:55 GMT 1
What do you use to stick the rubber trim on (lc2)
Post by midlifecrisisrd on Jan 4, 2018 20:34:30 GMT 1
Personally I use superglue
Glue lightly on the inside edge only
Sit the fairing on your knee and lightly apply about 1 inch at the bottom edge and put the trim on and hold till set.
Work your way round, you don't need it all glued so if you miss a bit it is ok
Be really sparing ( just a light dot every couple of inches so it doesn't show and if you break or scratch the screen you can get the trim off
Post by stusco on Jan 4, 2018 21:05:16 GMT 1
Cheers steve
