Post by mellow on Jan 4, 2018 11:03:17 GMT 1
Morning all. I need to replace the needle roller bearings in an alloy Suspension Link Arm. Is it ok & should i freeze the bearings before pressing them into the alloy link arm or will it knacker them? Cheers. Mick.
Post by headcoats on Jan 4, 2018 11:27:07 GMT 1
Good question
I have done it putting wheel bearings in but when you get the bearing out of the freezer, they get loads of condensation on them , but look at what bearings have to put up with in climates and conditions
Post by ypvs400 on Jan 4, 2018 12:26:30 GMT 1
Yes freeze the bearing and warm the link arm.
Post by mellow on Jan 8, 2018 16:52:34 GMT 1
Well i now have the new bearings. I'm only changing them as a matter of course as having Ohlins shock rebuilt. Pressed the old one ones out quite easily without heat, they really have not done many miles since i last changed them. My question is now that the bearings are covered in like a waxy, almost plastic coating inside, so no room to pack any more grease in I dug some out just to see what its like without the stuff So, what is yellow stuff? pre packed waxy grease? Should i add more grease not that there is anywhere for it to go? Any should i not freeze in case it messes the yellow stuff up? As said bearings press in quite easily Advice appreciated
dbgr
Post by dbgr on Jan 8, 2018 20:13:12 GMT 1
hi mellow ,that looks like the bearing comes pre-packed to me, unless you prefer a different grease I would just fit as they are.
Post by paulsx on Jan 9, 2018 10:44:59 GMT 1
Dont bother freezing the bearing just heat the arm/ link they are going in a bit. As said freezing causes condensation etc and its not really needed.
Post by mellow on Jan 9, 2018 23:28:08 GMT 1
Ok cheers men
