Post by andy748 on Jan 14, 2018 18:49:56 GMT 1
I got a spacer made and tapped to m10, then welded to my swinger prior to me painting it, the set up is the same as my 3hm1 model RZ, TZR 250 bracket and a German TZR125 rear wheel goes straight in, uses TZR250 caliper and disc. Andy. IMG_1660 by Andrew Jolly, on Flickr IMG_1661 by Andrew Jolly, on Flickr
Post by marrcel on Jan 28, 2018 13:14:35 GMT 1
Hi If you are using a Tzr125r Belgarda caliper carrier, You will struggle to mate that to the stock pv carrier boss that is on the inside of the swingarm. That's why I had to chop it off and do the torque arm mod. Dusty Thx David for info. Here szr660 to be fit in 1983 31k swingarm. Doing the torque arm mod. Looking for a fazer torque arm now. Chain alignment i have to take 9mm of the sprocket hub. The left axel collar length to be measured.
