Post by peebee on Dec 9, 2017 17:54:46 GMT 1
Hi .
I'd imagine this has been done many times before, I've done a forum search but nothing conclusive has turned up.
I have an RD350R with damaged front plastics, side panels and belly pan. What I'm planning is to change it to single round headlight with renthal type handle bars, looking similar to the 350N model but without the clip ons.
Is there another top yoke I can fit or do I have to modify the 350R yoke ?
Are there any potential problems with doing this ?
Any help or advice will be most gratefully received.
Cheers
Post by midlifecrisisrd on Dec 9, 2017 19:14:08 GMT 1
Hi
You need to fit an lc2 top yoke which will allow renthal
Complications as follows:
You have to drop the forks through the yokes to clear the bars (the bikes with clip on type bars have longer stanchions) so ride height will increase
Throttle cable ideally needs changed to an lc2 (29L) one to give more length
Clutch cable needs changed to lc2 again for length ( the R one may make it)
Clutch perch needs changed to lc2 to allow mirrors to be fitted
Post by peebee on Dec 9, 2017 19:35:29 GMT 1
Nice one Steve.
Thanks fella.
ps. I've just found a thread from someone a similar thing. pb
Post by bare on Dec 9, 2017 19:48:08 GMT 1
Long stanchions 'dropped to fit Will alter Trail/ Rake geometry. Noting that what often separates a Very good handling bike and one that isn't... is a VERY small difference there. Clever... to retrofit designed for the planned Yoke use Stanchions . . as well.
Post by wangwang on Dec 9, 2017 20:07:49 GMT 1
Post by Tobyjugs on Dec 10, 2017 11:48:59 GMT 1
Nice solution to the problem
Post by peebee on Dec 12, 2017 21:47:20 GMT 1
Nice solution to the problem It certainly is, and after much thinking that would be my preferred method, If anyone has any of those and are willing to sell them please post up or pm me. Otherwise I'm gonna buy a standard F2 top yoke, machine the top and bolt some risers to that.
Post by paulincayman on Jan 24, 2018 14:30:17 GMT 1
If you can find some 35mm ones, you can use this type of riser instead and keep the yoke as standard. Do you have a link to those or know who makes them ..had a search last night and couldn't,t find them ..cheers
Post by wangwang on Jan 24, 2018 20:45:03 GMT 1
If you can find some 35mm ones, you can use this type of riser instead and keep the yoke as standard. Do you have a link to those or know who makes them ..had a search last night and couldn't,t find them ..cheers Sorry, I did buy a couple of sets a good while back, there were loads on Ebay then. the 35mm ones went with a bike I sold and the ones in the pic are 38mm ones. They don't look too difficult to make though!
Post by dusty350 on Jan 24, 2018 20:49:12 GMT 1
M & p used to sell them. They have an online catalogue you can browse through. Dusty
Post by paulincayman on Jan 24, 2018 23:59:26 GMT 1
Cheers lads.
Post by dusty350 on Jan 25, 2018 9:03:06 GMT 1
Post by paulincayman on Jan 25, 2018 17:03:43 GMT 1
Thanks Dusty, great selection, but those seem to start at 36mm.....would have to resort to the old sliver of a beer can trick..
